Economy figures Patrol 3.0l diesel Manual
Submitted: Monday, Feb 17, 2003 at 02:29
ThreadID: 3404 Views:2299 Replies:6 FollowUps:6
Can anyone give me an indication of fuel economy/usage when towing a midsize pop top van or H/D camper trailer. Normal driving without towing usually returns around 12L/100kph. I am also aware that I will travel in 4th gear because of what I hear about 5th bleep ting itself.
Reply By: Mikef_Patrol - Monday, Feb 17, 2003 at 09:03
Hi Andrew
11.5l/110KM arount town
Sitting at 95kph 13.5-14.5L/100KM towing Jayco Dove Outback camper (about 1320KG fully loaded). At 100-110KPH drops to 15.5-16.0L/100KM
MikeF
AnswerID: 13294
Follow Up By: Andrew - Monday, Feb 17, 2003 at 16:17
Thanks Mike...
Do you tow in 5th gear....any problems???
FollowupID: 7813
Reply By: jeremy - Monday, Feb 17, 2003 at 15:53
g`day Andrew,,i tow an outback camper with my 3lt Patrol(around 800kg) and average around 14lt/100km........p.s whats this about 5th gear , i thought Patrol boxes were bullet proof !
AnswerID: 13310
Follow Up By: Andrew - Monday, Feb 17, 2003 at 16:16
Thanks Jeremy....
About the 5th gear....I've heard some scary stories about it demolishing itself if used for towing on and extended basis. A friend of mine who owned a 2000 model, the first release, had fifth bleep itself at 183,000km
Never towed a thing.
He'd fixed it ($3000) sold the car and bought a straight diesel 100 series cruiser. He now wishes he had just bought another Nissan 3.0L.
It could be bad luck, but i've heard it before and if you look at other QandA's in the forum, there is also reference to 5th gear going. IT may have been addressed in later editions (series II and III) but not sure. I know the oil pressure problem was fixed which was experienced in the 1st release.
FollowupID: 7812
Reply By: Truckster - Monday, Feb 17, 2003 at 16:31
3.0ltr GU's have a problem with 5th gear, its not a one off problem either.
Nissan have an upgraded gear shaft and gears now when they replace them.
Seems to be mainly when towing lots
AnswerID: 13320
Reply By: Mikef_Patrol - Monday, Feb 17, 2003 at 16:33
Hi Andrew
The fifth gear problem, depending who listen to, exists on both the 4.2 and 3.0L, and is related to the size of the splines on the 5th gear shaft, they are too narrow. Models built after about May 2002, I believe, have the new wider 5th gearset fitted. Someone may have more up-to-date info than me, Roly perhaps.
We have no problems towing in 5th at all, however, as a rule, we don't stay in 5th below 80kph. Puts less strain on 5th. If not, the warranty will cover it. It is a known problem. Also, use of synthetic oil in the gearbox will help as well, as it does not break down under load/heat as easily as normal mineral oils.
This is all info I have gathered from this site and the Overlander forum (http://forums.overlander.com.au/ , and try a search on "5th gear" or similar). You could also try the Patrol forum (http://groups.yahoo.com/group/Patrol4WD/) as well
I wouldn't worry too much. Knowledge is power, now you know what to do to prevent it. 8 Months and 16,000kms later we still love our 3.0L.
HTH
MikeF
AnswerID: 13321
Follow Up By: Andrew - Monday, Feb 17, 2003 at 16:43
No worries..
As a matter of interest, what is the build date of yours. Mine believe it or not is May 2002 as stated in your message. It's a series III with the different tail lights etc. So far so good, no worries 20,000kms 99% country roads, 99% 5th gear cruising
FollowupID: 7816
Reply By: Suzuki Viagra - Monday, Feb 17, 2003 at 18:27
The same 5th gear problem has been in place in Nissan Gearboxes since 1969 due to design of gearbox and gear placements....(maybe even before that but I knoiw bugger all about J and R series gearboxes. It can be fixed before it ever happens (but you'd have to pay for it since there technically isn't a fault at that time - or at least one that Nissan would admit to while they have to pay for it). That wouldn't cost much for anyone who knew Nissan boxes to fix.
The 5th gear eventually works its way loose so that when you try to shift into it and load it up it just steps out of the way - leaving you grinding a synchro but the gear's taken the previous bus and moved an inch away....
It's not even that hard to fix after the event - but by then it would be a warranty claim some years after warranty runs out. Rebuld cost is about $550-750 normally but all you need to do is pull apart the gearbox and retorque one nut....... If it's been bad for a while you need to replace that one gear and synchro (and in very rare cases the gear with the opposing face).
Usually if you use 'em hard without towing they do second gear synchro first - with towing it's normally 5th first due to synchro ratios, load, amount of use and size. In all of the 6 manual Nissan gearboxes with that gear layout that I have owned - I only broke 1 that way after 8 years abuse (and I ABUSED all of them including third gear rally slides in gravel). All the others had synchro whine (particularly 1st to 2nd and 2nd to 3rd) and were occasionally tough to shift but none of the others ever dropped a gear.
AnswerID: 13331
Follow Up By: Jeremy - Monday, Feb 17, 2003 at 19:25
wow .....thanks for all the info ....very interesting.I also have a 3LT Patrol built in may 2002 and am happy with it.I always wanted a Patrol through the GQ years and now finally in my mid 30`s have finally got one.I hope to have it for at least 4yrs and beyond if proves reliable on family trips to Flinders Ranges etc.Wrapped with fuel economy..anyway keep that info comin..much appreciated jeremy
FollowupID: 7828
Follow Up By: Sean - Tuesday, Feb 18, 2003 at 12:22
Thanks for the post Mr Suzuki. Its posts like yours that makes forums great places to visit.
Sean
FollowupID: 7860
Reply By: sean - Monday, Feb 17, 2003 at 19:30
Patrol 3.0l diesel 2000 model. 17 foot poptop > enonomy is about 6 km/l at 100 km/h. Drops to 5.5 km/l at 110. (I record fuel economy almost every tank). The 3.0 easily tows the van even up hills and overtaking at 100km/h.
As for 5th gear, I believe that the problem is inherent with overdrives. Also diesels are hard on gearboxes due to the compression and 4 cylinders are worse in this regard that 6's. The 3.0 litre puts out more torque that the 4.2 and it is easy to drive all day at 80km/h even when towing - and this is where is seems to be doing the damage (IMHO) so the problem is exacerbated with the 3.0 and has also been reported on this forum with the 4.2.
The nissan 4.2 adn 3.0 have the same box - so I think the problem may be more due to the strain/shock loadings that the 3.0 puts on the box than the box being different to other models of Patrol. The 3.0 has hydraulic engine mounts so this indicates to me that this engine VIBRATES and this is transferred no doubt into the box.
A friend of mine warned me early on about doing low speeds in overdrive (he has a hilux) and I did not believe him. Have to admit - he is right.
Sean
AnswerID: 13337
Follow Up By: Andrew - Monday, Feb 17, 2003 at 19:53
very true
thanks everyone for you input
FollowupID: 7830
