100,000km GU 3.0lt service
Submitted: Tuesday, Jun 06, 2006 at 15:47
Goons
What does the 100,000km service comprise of for a 2001 3.0lt manual?
I know the MAJOR $$$$$ service is every 40,000km were they change almost everything.
My understanding is that the 100,000km service is a normal 10,000km service & they also change the gear box oil & timing belt.
Some dealers say you never have to change the timing belt.
Every dealer i ring says something different. The Nissan dealer I reluctantly go to says skip the 5,000km service and just do em every 10,000km.
Anyone had the 100,000 service lately?
Reply By: Notso - Tuesday, Jun 06, 2006 at 15:59
Just a standard 10,000 service, the next big one is 120,000. The "Timing Belt" is actually a chain so doesn't need the regular replacement. (Like some others)
177046
Reply By: Alloy c/t - Tuesday, Jun 06, 2006 at 16:46
Ill get in before some other tojo driver ,,3lt nissan 100thou service requires the engine to be replaced,,,LOL nah not realy unless its a series 1.
177059
Follow Up By: Goons - Tuesday, Jun 06, 2006 at 16:57
Alloy
What series 1 are you talking about cos there never was a 3.0lt series 1.
433067
Follow Up By: Notso - Tuesday, Jun 06, 2006 at 18:09
God some people are so cruel,
my GU11, the first with the new 3.00, has done 176000 now and running better than ever.
433078
Follow Up By: Alloy c/t - Tuesday, Jun 06, 2006 at 18:14
Goons ,, the first of the 3lt nissan patrols = series 1 ,,, the motor "fix" by recall was to "shorten" the dipstick so normal was 2lt more oil ,, second recall ,,ie series 2 was increase sump size by ??? yes !!! 2lt ,,, so many on this and other forums have had total engine failure that one would sugest buying a 2nd hand 3lt nissan patrol prior to 2003 is like playing Russian roulett ,,dont get me wrong ,my tojo 80series in early mods have/had a major problem as
well..
433079
Follow Up By: Goons - Tuesday, Jun 06, 2006 at 18:26
Alloy
I wasnt asking about recalls, 2nd hand cars, sump sizes, dipsticks etc.
What i want is knowledgable info on the 100,000 service which you obviously dont have
For what its worth tho the Series 1 GU was a 2.8lt
433080
Follow Up By: Alloy c/t - Tuesday, Jun 06, 2006 at 20:20
Goons , you sure ,because A. you seem to know jack sh-te about your own vehicle ,and B your dealers seem to know as much as you do ,,twas an old radio show ,"the goon show" at least they had intelligence ,something you seem to seriously lack,
433101
Follow Up By: A.J - Tuesday, Jun 06, 2006 at 22:02
Doesn't it tell in in the Owners' Manwell?
433122
Reply By: Peter - Tuesday, Jun 06, 2006 at 17:18
Goons,
Just coming up to 100,000km service on my 2003 4.2. Read the Nissan documentation and it states to change the timing belt, however when I made enquiries about it was advised it is actually a timing chain and does not need replacement. I suppose the 3.0 is the same. I was advised that the timing belt virtually lasts forever but what does wear is the guides. These sometimes do need replacement but it's not as critical as replacing an actual belt.
My quote for a the 100k service was around $175.
I replace my own gearbox, transfer case and diff oils. Easy to do and saves a fair bit on labour.
177064
Follow Up By: djpatrol - Tuesday, Jun 06, 2006 at 17:34
Hi Peter, gotta do my gearbox transfer case oil change etc in 4.2 td can you tell me if I would need a Pump of some kind to get oil back in to both and any info would be great.
thanks denis...
433074
Follow Up By: djpatrol - Tuesday, Jun 06, 2006 at 17:35
It is a GU Patrol Peter...
433075
Follow Up By: Peter - Tuesday, Jun 06, 2006 at 19:30
djpatrol
I bought a small pump from
Supercheap which just screws on to the top of a 5 litre oil container. It comes with a length of hose to attach to the spout and just poke it into the fill hole. I find I can lay under the car without raising it and then sit the container on the ground and the hose is long enough to reach into the gearbox etc. It's a bit of a pain because the boxes take so much oil, so you're arms get plenty of exercise, but considering the cost saving I'm happy. Can't remember how much the pump was but I'm pretty sure it was
well under $10.
Mine is a GU 4.2 td so you should be pretty right.
Good luck with it
433088
Reply By: Member - Axle - Tuesday, Jun 06, 2006 at 19:28
Goons.
Surely the Nissan documentation in their service schedules is not that confusing, that you do not know what is to be done at each service interval? Big difference between timing chain and timing belt, big difference between 5000kms and 10000kms service intervals. Nissan have been subject to criticism on their earlier GU engines, review posts for the last 12 mths!
I think dealerships these days should be more conscientious of their customer relationship.
Axle
177082
Reply By: 120scruiser (NSW) - Tuesday, Jun 06, 2006 at 21:45
Goons
The Nissan service book is used in many different cars and across many models so thats why it states to replace timing belt. You will find it is not ticked in your book.
Your 100K service is just a normal service.
Alloy
The series 1 was released in 1998 in 2.8 litre and 4.2 litre diesel versions. The series II was released in 2000 and was the first of the dreaded 3.0 litre diesels and the series III was released in 10/01 and is defined with clear tail lights, extra sensors in the ZD30 engine and clearer, ie less pattern in the headlight glass.
Refer my website for further info.
Patrol Information
Probably some more defined research wouldn't go astray.
120scruiser
177109
Reply By: dieselup - Wednesday, Jun 07, 2006 at 07:03
Whatever you do Goons dont skip the 5000k service oil's cheap and iron's expensive
At the milage you have on your's you need to be able to monitor what's going on in that engine. You should be cutting the old filter open after each service and checking for any metal at least if you find any problem you can get onto it quickly
Mine got to 210000k before we found any serious problem but we at least avioded a major failure
good luck
177143
Reply By: rob1 - Wednesday, Jun 07, 2006 at 08:06
Goons,
I have a late 2001 manual 3 ltr and had the 100K service done earlier this year.
The
Sydney dealer I went to just did a routine service (ie; "inspect") I change the oil & filters myself, use the Nissan Semi Synthetic engine oil, so asked them not to do it (they use a different oil because they have a contract with a different supplier). They did do an "on car" injector clean ( a bottle of injector cleaner in the fuel
tank I suspect) and charged $80 for it. The timing belt is a chain and doesn't need replacing. The tappets aren't adjusted (only if noisy). I checked with half a dozen Nissan Dealers throughout
Sydney and all of them said they have never had to adjust tappets. So, all in all, just a basic service.
Rob
177156
Reply By: Truckster (Vic) - Wednesday, Jun 07, 2006 at 11:36
usually an engine replacement.
177192
Follow Up By: mick - Wednesday, Jun 07, 2006 at 12:13
Cant help yourself can you!!
Do you wake up in the morning and think "what can I do today to be annoying"
433196
Follow Up By: Truckster (Vic) - Wednesday, Jun 07, 2006 at 12:21
433198
Follow Up By: mick - Wednesday, Jun 07, 2006 at 12:30
Very Good!!!!
433202
Reply By: Goons - Wednesday, Jun 07, 2006 at 17:47
Alloy CT
FYI
I do know Jack Schitt & his whole bloody family
Jack is the only son of Awe Schitt and O. Schitt.
Awe Schitt, the fertilizer magnate, married O. Schitt, a partner of Kneedeep &. Schitt Inc.
In turn, Jack Schitt married Noe Schitt, and the deeply religious couple produced 6 children: Holie Schitt, Fulla Schitt, Giva Schitt, Bull Schitt, and
the twins: Deep Schitt and Dip Schitt.
Against her parents' objections, Deep Schitt married Dumb Schitt, a high school drop out. After being married 15 years, Jack and Noe Schitt divorced.
Noe Schitt later married Mr.
Sherlock, and
because her kids were living
With them she wanted to keep her previous name.
She was known as Noe Schitt-
Sherlock.
Dip Schitt married Loda Schitt and they produced a nervous son, Chicken Schitt.
Fulla Schitt and Giva Schitt were inseparable throughout childhood and subsequently married the Happens brothers in a dual ceremony. The wedding announcement in the newspaper announced the Schitt-Happens wedding.
The Schitt-Happens children were Dawg, Byrd, and Hoarse. Bull Schitt, the prodigal son, left
home to tour the world. He recently returned from Italy with his new bride, Piza Schitt.
Maybe you should have been recalled, I think you were issued with nine tenths of ya brain missing and an oversized uneducated mouth.
177260
Reply By: Member - Steve & Paula - Sunday, Jun 11, 2006 at 23:36
I have a 2002 Gu II and was quoted $695 for a 100,000 km service this week by a Nissan dealer. Seems a lot, but what if the timing belt breaks in the middle of nowhere? The service manual will give conservative maintenace schedules for obvious reasons and many may get away with less, but ....
178023
