Prado steering noise
Submitted: Friday, Jun 16, 2006 at 10:56
ThreadID: 34978 Views:2586 Replies:2 FollowUps:0
My 95 series Prado is making a strange noise when the steering is on full lock, in either direction. It's not the tyres rubbing - the noise still occurs when I turn the wheel while the car is stationary, but only in the last couple of degrees. It seems to be coming from under the bonnet. I assume it is to do with the power steering.
Any suggestions?
Reply By: Member - Steve (ACT) - Friday, Jun 16, 2006 at 12:33
Check the belt that runs the pump, make sure it's not loose!
Steve
AnswerID: 178777
Reply By: George_M - Friday, Jun 16, 2006 at 14:46
Just back off on the steering a couple of degrees, Des.
It has got something to do with the power steering, and the noise you've mentioned has occurred in each of the four Prados I've owned.
George_M
Come any closer and I'll rip your throat out!
AnswerID: 178799
