Idleing too fast
Submitted: Saturday, Jun 17, 2006 at 12:52
ThreadID: 35011 Views:4353 Replies:7 FollowUps:1
Hi all,
I have one of the infamous zd30 patrols (auto), over 120 000k and generally going well. However I have noticed in the last week that the revs are creeping up from the usual 750 at idle to around 10000 - 12000. This happens when I put it in park.
Its ok when I first start up, just happens later after I have been driving for a while. I have checked the fault codes, but are all clear.
Any suggestions what might cause this?
PJ.
Reply By: Andrew (Bris) - Saturday, Jun 17, 2006 at 13:20
Similar thing happened to me recently.
Was simply a loose conection on the warm-up switch. Pushed the plug onto the switch tighter, and never happened again.
Hope your's is so simple.
AnswerID: 178927
Reply By: Phil P - Saturday, Jun 17, 2006 at 17:34
Had a similar problem with my GU. The dealer simply hooked up some test device for a few seconds and it was then back too normal. No Charge!
AnswerID: 178960
Reply By: Geoff (Newcastle, NSW) - Saturday, Jun 17, 2006 at 18:20
"10000 - 12000" fair dinkum, Michael Schumacher would be proud of that!!
Other suggestion, does the Patrol increase rev's when the air conditioning is switched on? If so is it possible the vehicle thinks the AC is switched on?
Geoff.
Geoff,
AnswerID: 178967
Reply By: ACDC - Saturday, Jun 17, 2006 at 21:39
P.J
Had a patrol doing the same thing the boost sensor was faulty causing the fast idle.
AnswerID: 178996
Reply By: Dirty Smitty - Saturday, Jun 17, 2006 at 23:08
10000 - 12000 rpm!!!!!!!!!!!!!! Dude thats one screaming diesel!!!!!!!!!!!!! I have to get me one of those zd30 engines. Must be a special nissan engine release/limited edition?
AnswerID: 179012
Follow Up By: Kenell - Sunday, Jun 18, 2006 at 10:48
Dirty,
I'd happily sell you mine but can't guarantee that rev capability. I can guarantee it has a new cyl head though so if you want to give the revs a try it might last a little longer than one without the new cyl head. Just let me make sure the funds have cleared into my account before you hit the skinny pedal.
Kenell
FollowupID: 435333
Reply By: pauljohnston - Sunday, Jun 18, 2006 at 16:55
OK so I was a "bit" generous with the 0's. Thanks for the advise though.
PJ.
AnswerID: 179075
Reply By: pauljohnston - Wednesday, Jun 21, 2006 at 17:15
Hi all,
You might be interested to know that problem seems to have settled itself. I'm thinking it might have happened when I checked the fault codes, (only 0505), then cleared the codes. Has run fine ever since. Perhaps that is what ealer did when he hooked up yours.
PJ.
AnswerID: 179697
