100 series clutch shudder
Submitted: Saturday, Jun 17, 2006 at 22:10
ThreadID: 35025 Views:2174 Replies:4 FollowUps:1
hi every one,
i have a 100 series 1hz diesl which until 2 days ago had terriable clutch shhudder
and has had it from the day i bouht it
after a clutch replacement under warranty it lasted about a week i had clutch kit and a new fly wheel under warranty and it drove me mad well iwill let you know that there is a solution to this problem and that is a safari tuff clutch by daiken best money i spent they at first choise clutch and brake at east maitland and carters clutch service also at maitland say that this is the answer to the problem
Reply By: Member - Andrew W (SA) - Saturday, Jun 17, 2006 at 23:57
what cost the part and fitting?
what warranty did they give?
AnswerID: 179018
Follow Up By: black bull - Monday, Jun 19, 2006 at 21:15
hi andrew,
im not sure what it would cost to fit as i did it myself. it took about 4 hours to remove box,clutch and flywheel.i got the fly wheel machined at a cost of 27.50. clutch kit was 500.00 andspigot bearing was 15.00 then it took me about the same time to put it back togeather
hope the info helps
FollowupID: 435560
Reply By: crewser - Sunday, Jun 18, 2006 at 10:02
Are you saying you had clutch fitted 2 days ago? but the last clutch lasted a week before started to shudder, your getting a bit excited arn`t you?. Hope it lasts a bit longer than the last one, and yes I know how made it drives you (Im a 100s owner)
I would also like to know what it costs.
AnswerID: 179038
Reply By: Gerry - Monday, Jun 19, 2006 at 09:29
As per my comments in a previous thread, I fitted a Daikin clutch some months ago and have done a couple of trips since, including some heavy towing and no more shudder!
It should fix your problem no worries.
Gerry
AnswerID: 179157
Reply By: falcon74656 - Monday, Jul 17, 2006 at 12:46
were did you buy the clutch kit from? I tried both of of those places and was quoted about $610.
Thanks.
AnswerID: 183896
