Supercheap air compressor returned for Airmax
Submitted: Sunday, Jun 18, 2006 at 16:26
ThreadID: 35040 Views:2661 Replies:1 FollowUps:1
Bought a supercheap 72lire/min air compressor after hearing from a friend that they are very similar to the Airmax and about $200 cheaper. Hooked it up to check out and that it works –well I was back at the shop the next morning to get a refund. Supercheap kindly offered the choice of refund or swap, with no problems.
The air hose fitting to the pump had a major air lead and only doing 20psi. Also looked a bit light with a few kinks and the pump base was missing a rubber foot. The quality was a bit less then I would like so went the refund.
Went next door and bought an Airmax. Hooked it up, works great. Much better quality finish and fittings - worth the extra dollar.
Cheers Anthony
Reply By: Member - Omaroo (NSW) - Sunday, Jun 18, 2006 at 17:45
The "Airmax or" Maxair" ?
AnswerID: 179084
Follow Up By: Anthony - Sunday, Jun 18, 2006 at 21:13
Maxair - best I start using its correct name. I recon airmax sound better though.
FollowupID: 435407
