Monday, Jun 19, 2006 at 21:09
Actually, found this via google on aust site by meguirs products on saving
water during car washing:
1. Drill a 25mm diameter hole at the base of a large bucket - 15 Litre size is best. (Fig 1)
2. Fit garden hose fitting with shut-off valve - available from any good hardware supplier. (Fig 2)
3. Fill the bucket and place it in a position higher than the machine, so the
water will gravity feed. Attach snap-on connector fittings to each end of a 1m length of garden hose, and connect one end to the bucket. For the Lavor EKO machine, we recommend a 3m length of garden hose. Open the shut-off valve and ensure there is
water flow, then connect to the machine. (Fig 3)
4. Turn on the machine and wait for the high pressure
water flow to the lance and you’re set to go. Take note to refill the bucket before the
water level gets too low. (Fig 4)
Note: Not all high pressure cleaners are suitable to run off a bucket. We have successfully tested a range of Karcher machines as
well as the Lavor EKO machine from Repco and the Superworks machine from Super Cheap Auto. The manufacturers of GMC, Gerni, and Kerrick machines have advised that they are not designed to operate from a bucket. With any other machines please check with the manufacturer first.
435559
