cruise controls
Submitted: Sunday, Jul 02, 2006 at 23:29
ThreadID: 35475 Views:3987 Replies:5 FollowUps:8
I'll start by saying "I did the search"
I'm keen to know what cruise control models people have fitted to their GU patrols with the 4.2 turbo motors?
A guy tried to sell me a Command AP500 but it was a bit pricey. It looks to me that an AP 60 would do fine at less than 1/2 the price.
Thoughts?
Thanks in advance,
NickR
ps.
I'm sick of speeding tickets for being a poofteenth over the limit thanks bracksy......
Carpe Cerevisi
Reply By: joc45 - Monday, Jul 03, 2006 at 00:49
Hi Nick,
Been running an AP50 for the last 5 yrs or so on my GU turbo, no probs. Only criticism is that the magnets on the tailshaft can be an issue, both in being knocked off, and the signal being lost over rough roads, incl bitumen, causing dropouts. The unit performs well otherwise. I've posted a circuit of a mod to get around the magnets on the Yahoo Patrol website (think it's still there, haven't checked for a couple of years).
Gerry
AnswerID: 181523
Follow Up By: V8 Troopie - Monday, Jul 03, 2006 at 23:21
Try this if you have magnet adhesion problems:
1. forget the tailshaft, use the transfer box output flange instead to affix the magnets. It does not bounce about like the tailshaft.
2. file two little flat spots 180 deg apart to give the magnets a very good adhesion, use high strength epoxy glue and scrupulously clean flange and magnets with acetone before glueing.
3. use the metal caps & tie wires supplied to give the magnets additional mechanical support.
The above method has held well so far on my troopie, No I have to look and see what alternative method to get a signal you came up with on that yahoo site.
Klaus
FollowupID: 438000
Follow Up By: joc45 - Tuesday, Jul 04, 2006 at 04:53
Klaus,
Yeh, looked at that, but on the Patrol there is a large handbrake drum, with the flange not really accessible, and it's not an easy solution. The electronic solution is to use the speedo pickup (wiring found in the engine bay) and a relatively simple electronic interface to the AP50. Nice and reliable.
But for the Troopie, your solution is probably simpler.
But where I've fitted the unit to other machines, I have roughend the metal surface, slopped araldite between the magnets, plus smeared araldite over the wires which hold the magnets on. Pretty reliable. But even when I did this with the Patrol, gearbox/tailshaft shake on rough bitumen caused the magnets to drift too far from the pickup to cause momentary signal loss, and dropout on the AP50.
rgds
Gerry
FollowupID: 438017
Reply By: handy - Monday, Jul 03, 2006 at 07:50
after seeking advice on this site i bought the AP60 from supercheap for $189
works a treat on my GQ td 42. cheers
AnswerID: 181532
Reply By: Member - Mike DID - Monday, Jul 03, 2006 at 09:14
Nick
I have a Brand New in Orriginal Box AP60 for sale for $100. Changed cars after buying the AP60 and it had Cruise Control in it.
Mike
AnswerID: 181548
Follow Up By: pauljohnston - Monday, Jul 03, 2006 at 11:51
Would this work in a zd30 engine?
PJ.
FollowupID: 437874
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jul 03, 2006 at 12:09
Mike, have MM'd you about Nick's contact details. He says he would take that thanks.
PJ, this is the older style better for the throttle systems rather than drive by wire. Perhaps AP150 listed at Site Link
FollowupID: 437877
Follow Up By: RedGibber - Monday, Jul 03, 2006 at 19:10
I installed the AP150 last year in my TD42T. Couldn't be happier!@! Speed sensing is done from a "tap", off the sense wire in the dashboard. No magnets to worry about!!
RedGibber
FollowupID: 437932
Follow Up By: angler - Monday, Jul 03, 2006 at 20:23
I tried one of the vacuum systems on my 3 litre and it failed badly. Nowhere near enough grunt to pull the pedal. The motorised one I think is AP500 is the better one. The best of course is the autron however it is near impossible to get here in the north.
Pooley
Townsville
FollowupID: 437944
Follow Up By: Nick R - Tuesday, Jul 04, 2006 at 11:46
Give us a call mike, sounds good
nick
Carpe Cerevisi
FollowupID: 438053
Reply By: chips - Tuesday, Jul 04, 2006 at 01:45
My brother fitted an AP 50 to his 1991 4.2 D (non turbo) patrol a couple of years ago and loves it hasn't given him any problems. I picked one up 2 weeks ago from KMART for $118 reduced from $209 as they are now a deleated stock item, im hoping to fit it to my 1999 4.2 D patrol (non turbo), unfortunatley little bro. has just moved up north so im going to have to fit it myself (bummer).Bro. said it wasnt hard to fit just fiddely - after looking at instructions im getting "cold feet". Are there any problems fitting that I should know about?
appriciate advice.
sorry to hijack Nick
thanks all
Chips
AnswerID: 181709
Follow Up By: Nick R - Tuesday, Jul 04, 2006 at 11:47
unfortunately it is already out of stock in Warrnambool
Nick
Carpe Cerevisi
FollowupID: 438054
Reply By: Truckster (Vic) - Tuesday, Jul 04, 2006 at 12:23
Doesnt the Pov pack come with cruise?
tsk tsk tsk
AnswerID: 181748
