Inverters - Which One?
Submitted: Monday, Jul 03, 2006 at 18:16
xtragrouse
Hi Guys
I have just been supplied a Resmed S8 CPAP machine with Humidifier, and am now in a quandry as to which inverter I should buy.
It seems that 200w is the minimum I should consider, and my choices so far seem to be:
Selectronic LD from the 12volt
shop $535, Made in Australia 200w 2 yr warranty
Powertech 300w from Jaycar, $299, made in (? China maybe) 1 year warranty.
In my experience, cheap is only when you pay for something and it works
well, otherwise, it is expensive, regardless of how little you paid for it.
Can anyone give me an opinion on these units, as I need to purchase and instal before the weekend.
Reply By: guzzi - Monday, Jul 03, 2006 at 19:38
Does it need to be sine wave or will modified wave do?
I have a fisher and paykel and am looking around for the same reasons as you, the tech I spoke to said
mine would run on modified wave but would perfer the pure sine wave variety. Is a saveing of $236 worth $1000 + dollars for a new cpap?
Mine requires a "minimum" of 300w, Im tending to look at the 500w units, Im not likeing the answers on price either.
That and the size of the batteries required to run it for longer than a night or 2.
Does the S8 also run on 12V??
181647
Follow Up By: xtragrouse - Monday, Jul 03, 2006 at 19:59
Both units are pure sine wave. I spoke to a guy who has had the cheaper unit for a couple of years and it works fine apparently. But I am just trying to get the right thinking in my mind.
Yes, the S8 will run on 12v, but not with the humidifier. Resmed have their own 12v converter for $99. But of course, if you are going to the expense and looking long term, then it's worth doing it right to start with.
It sounds like you have a HC230 or HC600, which needs either a modified square wave or Pure Sine wave (Output specifications should match 300w/500w continuous/surge) according to the inverter guide given to me by SJOG hospital Sleep Centre in
Perth.
437941
Reply By: itsdave - Monday, Jul 03, 2006 at 21:03
I'm using a 150 w Alessi pure sine wave for my Resmed S7. Will run the CPAP fine without the humidifier and can usually get 3 nights out of a 105 a/h AGM battery. If you can get away without using the humidifier then you can save on quite a lot of
battery power. When I bought
mine I was told that for most medical equipment, pure sine is recomended.
Cheers Dave
181663
Reply By: Truckster (Vic) - Monday, Jul 03, 2006 at 21:56
Site Link
500 Watt (1000W Surge) 12 VDC to 230 VAC Electrically Isolated Pure Sine wave Inverter
Techstore Special Only
Not available through stores
- Ex-Repaired Stock -
Very limited in quantity
Pure Sine Wave
This excellent inverter is rated at 500 watts continuous output and is electrically isolated between battery and secondary voltage. The unit is designed for fixed mounting and high performance. Housed in a strong aluminium case, the inverter features heavy- duty screw down input connectors, cooling fan, 3- pin 230VAC output socket, on/off switch and LEDs to indicate normal operation, overload condition and over temperature. The inverter output is fully protected against short circuits and overload. Typical applications are laptop computers, power tools, blenders, small refrigerators & microwave ovens etc.
Specifications:
- Output Power: 500 W continuous
- Surge Power: 1,000 W
- Standby Current: 1,400mA
- Input Voltage: 10 - 15V DC
- Output wave form: Sine wave
- Efficiency: >85%
- Output Regulation: +/- 3%
- Output Frequency: 50Hz
- Cooling: Internal fan
Protection:
- Output Short: Output short without blowing fuse
- Low Battery Alarm: <10.7 Volts
- Low Batt. Shut- off: <10 Volts
- Overload: Shutdown
- Battery reverse: Internal 40A Blade Fuses
- Input connector: 4 gauge
- Dimensions: 236 (W) x 83 (H) x 335 (L)mm
- Weight: 3Kg
QTY
1+ $179.95
181679
Follow Up By: cipher - Monday, Jul 03, 2006 at 22:19
running the same inverter in my car,
just a caution if you are using this inverter to power a Toshiba notebook dont expect to use your touch pad (mouse) on your laptop as it cuts it out for some strange reason :-S
Also draw alot of power if just left on with no load... However good that it doesnt require a reboot when you kick back in the charge on the battery that it is running off
otherwise a great inverter
Justin
437974
Follow Up By: Squizzy - Tuesday, Jul 04, 2006 at 10:11
Any ideas on how to get the Powertech 500w going again after the overload light comes on?
The light came on when the unit was switched on after some fairly serious corrugations recently.
Geoff
438039
Follow Up By: cipher - Tuesday, Jul 04, 2006 at 14:34
Yeah it could be that there is dust in the unit...
If it is under warranty simply return in, if not try and blow out the dust check that the fan is still spinning...
All else fails try removing power to the unit for some time (let the caps discharge) then try again, could help?
justin
438079
Follow Up By: Squizzy - Tuesday, Jul 04, 2006 at 15:53
Thanks Justin,
The unit is out of warranty (2 years).
I will blow some dust out (although it should be clean where it is mounted) and try to hook it up again and see how it goes.
Geoff.
438101
Reply By: Raymond from Wanderin 4 Wheelers - Tuesday, Jul 04, 2006 at 08:11
We have a Jaycar 750watt pure sine wave one in the motorhome and it works great. Jaycar are fine and look after you
Ray
181719
Reply By: Member - Leigh (Vic) - Tuesday, Jul 04, 2006 at 08:52
For the life of me I cannot understand why you don't buy a CPAP with 12V capability. All this mucking around only detracts form what you are trying to enjoy...just too many hassles!! IMHO of course.
181726
Reply By: Member - JohnR (Vic)&Moses - Tuesday, Jul 04, 2006 at 10:02
If you need an humidifier as
well and most do these days I understand, you will need 300W with a good sine wave. I have a DSE one. Make sure your connections are all good to it, even if you have a 50 amp Anderson plug, you could have problems occasionally with some dirt or something restricting the connection.
I think my DSE one is modified sine wave.
As to whether you go for a 12v one, some of the newer ones have a 12v capability to connect somehow, but it is good to have a log of your treatments for compliance purposes, which ever way you go. Having been diagnosed, an electronic log in case of accident will be a lot better for any insurance purposes.
181734
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Jul 04, 2006 at 19:43
Give me a ring.
181824
Follow Up By: Truckster (Vic) - Tuesday, Jul 04, 2006 at 22:11
438184
Reply By: xtragrouse - Wednesday, Jul 05, 2006 at 00:06
thanks for your input guys. Have purchased the Powertech 500 watt model from Jaycar, it gets installed tomorrow, and then on Saturday, we head for the Gunbarrel.
181888
