Drawer Systems
Submitted: Monday, Jul 03, 2006 at 18:27
ThreadID: 35494 Views:3431 Replies:13 FollowUps:4
G,day all,
With respect to drawer systems and slide outs for the fridge, what might be the best side to have this on.
Same side as the door is hinged or the opposite?
I figure I'll get a 50/50 response for that one...LOL
No but seriously is any one way better for easier access and general usage when the fridge is onboard and your accessing the other (read) DARK SIDE!!!!!
From all the real life usage I'm sure the responses will be varied.
Garth
Reply By: Member - BUNDY BOY (WA) - Monday, Jul 03, 2006 at 18:45
hi garth...........depends on the drawsystem ...some dont have the option ..also depends on the truck :eg:my patrol..sml door Lhs easyer to get ods n ends out of without opening right up ..........fridge is on the right ..........realy a persoal choice i think .....cheers bundy
AnswerID: 181633
Reply By: Member - Brian (Gold Coast) - Monday, Jul 03, 2006 at 19:16
same as Bundy boy.....
AnswerID: 181639
Reply By: Alloy c/t - Monday, Jul 03, 2006 at 19:20
Well wont this one be a conundrum ? We have the 80lt Waeco on the slide of the drawer unit on the drivers side ,the way it faces lets me see in the rearview mirror how many Led`s are on ect ,the baby 15lt Engle is mounted on the passenger side with the dial to the front for the same reason , this does not allow us to access either fridge while mobile however ,. never found it to be a problem ,,outback drawer system in an 80seriesGXL.
AnswerID: 181641
Reply By: Crackles - Monday, Jul 03, 2006 at 19:26
What vehicle Garth........It makes a big difference.
Cheers Craig.........
AnswerID: 181644
Follow Up By: Garthski - Monday, Jul 03, 2006 at 20:55
Craig,
03 Prado.
Door hinged on the drivers side.
Garth
FollowupID: 437952
Follow Up By: Crackles - Tuesday, Jul 04, 2006 at 19:39
From my exerience the fridge should go on the LHS mounted as low as possible for easy access with 2 draws on the RHS. On the Playdoe many fit a drop down table on the rear door so with a fridge on the left you can still open it and transfer food accross. Put your other food & eating gear in the top draw which can also be opened with the table down. If your fridge isn't a whopper there will be space to fit 3 jerry cans between the boxing system & the back of the seats.
Cheers Craig..............
FollowupID: 438143
Follow Up By: 120scruiser (NSW) - Wednesday, Jul 05, 2006 at 21:42
Exactly how I have mine set up crackles except I have a 45 litre water tank behind the seats instead of the jerry cans.
Garthski if you want some photos of my prado just send me an email to
webmaster at out and about 4wd dot org dot au and I can email some photos over to you.
120scruiser
FollowupID: 438380
Reply By: Tim@Stratford - Monday, Jul 03, 2006 at 19:27
I've got the Outback drawers and fridge slide fitted in my 100s. Fridge slide is on the driver's side as per my choice at purchase. In hindsight I should have put it on the passenger's side. This would allow the bar of my chainsaw to slide behind the fridge and save space. Unfortunatley this isn't possible with the fridge on the driver's side - my two cents worth. :-)
AnswerID: 181645
Reply By: Member - Peter A (VIC) - Monday, Jul 03, 2006 at 21:30
Garth,
We have a Prado as well and our home made drawer system has the engel on the left hand side and 3 drawers on the left hand side, I opted for the drawers to be on the side as its lower and easier to get to the fridge, its an option you might want to look at when height is a problem.
Cheers Peter.
AnswerID: 181669
Reply By: bushcamper - Monday, Jul 03, 2006 at 21:33
G'day Garth, this works but I'm thinking of changing it to two low drawers (about 120mm high) with a removeable fridge slide and cage on the left and a fold down table on the larger right hand door.
This will allow me to use the back for other things when we're not on the road.
Keith
http://img.photobucket.com/albums/v623/longbow1/Nissan/P9190050.jpg
AnswerID: 181672
Reply By: Member - Peter A (VIC) - Monday, Jul 03, 2006 at 21:33
Garth,
Sorry mate a bum steer there, I meant engel on the left and drawers on the right, a few too many cans and few more mistakes on the keyboard
Cheers Peter.
AnswerID: 181673
Reply By: bushcamper - Monday, Jul 03, 2006 at 21:37
Try again
AnswerID: 181674
Follow Up By: Member - Phil G (SA) - Monday, Jul 03, 2006 at 22:52
Thats cheating - you've got doors on both sides :-))
FollowupID: 437988
Reply By: RayJen Paj05 - Monday, Jul 03, 2006 at 22:55
Garthski - a valid alternative works for us in our '05 Pajero which has a huge back door bolted on the drivers side and opens only about a quarter when the Aussie Swag is connected. We have a CF-50 Waeco. We removed the seat behind the front passenger and had a platform installed bolted to where the seat is normally secured.
It is anchored with the usual webbing and buckles so is totally safe and we still have lots of room for 2 passengers in the back seat.
We have very easy access to the fridge via the passenger side rear door.
Food for thought?? (pardon the pun!)
Cheers, Ray & Jenny W
AnswerID: 181688
Reply By: Member - Phil G (SA) - Monday, Jul 03, 2006 at 22:55
On the 90series I redesigned the rear storage 4 times - it was a lot of fun. Final setup had fridge on left side, on floor level, with hutch above it for stove etc. then on the right, had 2 drawers - one was the right height for a slab, the other was the right height for a cask. By good fortune everything else fitted in :-)))
AnswerID: 181689
Reply By: Member - Pezza (QLD) - Tuesday, Jul 04, 2006 at 12:26
Hi Garth,
Another thing to think of is if you are ever going to fit a hinged drop down table to the inside of the rear door, when you are making a quick lunch and have plates, coffee and various other things on the table and need to get something out of the fridge you might be glad you put it on the passenger side, this being one of the reasons I fiited mine there, have a look at my rig pics for an example.
Avagoodn
Pezza
AnswerID: 181752
Reply By: Bob - Tuesday, Jul 04, 2006 at 13:43
I suppose Ill have to move my fridge to the centre.
'cause I've got a drop down tailgate and a lift up canopy door.
AnswerID: 181766
