Duel Batteries
Submitted: Monday, Aug 13, 2001 at 00:00
ThreadID: 355 Views:3703 Replies:7 FollowUps:2
I have a 80 series Cruiser (petrol version) and was wondering if anyone had a wiring diagram and parts list to install a duel battery system.
Reply By: Jeremy - Tuesday, Aug 14, 2001 at 00:00
I have some detailed information on battery management systems on my web page : http://communities.ninemsn.com.au/JeremyCookesLandroverDiscoverypage check it out and email me if you ned any more info !
Good luck, Jeremy.
AnswerID: 881
Follow Up By: David - Thursday, Aug 16, 2001 at 00:00
Thanks Jeremy will take a look.
FollowupID: 262
Reply By: richie rigg - Wednesday, Aug 15, 2001 at 00:00
Dave
i am an electrician + kept the installation from my 80 series includes toyota kit, solenoid + heavy wiring loom.will sell if interested.$100 plus postage. regards richie
AnswerID: 904
Richie can you email me direct so i can ask you a few questions about it. Use dsc000@optushome.com.au and i will reply
Thanks David
FollowupID: 261
Reply By: ken - Thursday, Aug 16, 2001 at 00:00
David
why do you want a wiring diagram?
just go to a 4wd store and get a dual battery kit which gives you a battery tray to suit your vehicle an isolator and all the relevant fittings
AnswerID: 911
David
AnswerID: 912
David
AnswerID: 913
Reply By: Lisa Ayoub - Tuesday, Sep 04, 2001 at 00:00
David, I tend to agree with Ken. The easiest way is to go to a 4WD store and buy a kit. Make sure you do your research before you decide which kit to buy though. There are many different kits available. I ended up buying the Piranha 150DBE kit for the following reasons. It has a sensor to detect when the engine is not charging the batteries and shuts the kit down meaning that both batteries are completly isolated from each other. No voltage can flow backwards or forwards which means you can be confident of flattening the second battery while still having a charged main battery. (if the main battery does go flat you can use jumper leads to start the car). The second reason is the kit is fully surge protected (no spikes can get through) There were a couple of other reasons I cant think of off the top of my head but these are a good start.
AnswerID: 1018
Reply By: Paul Cooke - Tuesday, Sep 04, 2001 at 00:00
David,
I agree with Lisa I too have the piranna system, it was on my 80 series for 5 years went through the simpson, flinders and many club trips with no problem. the same one is now fitted to my 100 series and still performing well and is easily fitted by the average person in a couple of hours.
Hope this helps
Paul
AnswerID: 1023
