Pajero 1995 petrol
Submitted: Tuesday, Jul 04, 2006 at 22:36
ThreadID: 35533 Views:2057 Replies:4 FollowUps:1
any offer problems with wear on clutches in these vechicles. Towing a 700kg trailer
Reply By: Andrew-rodeo - Tuesday, Jul 04, 2006 at 22:50
The clutch should be fine, depending on KM's done. You could nearly tow a 700kg trailer behind a push bike, you want even know its there
AnswerID: 181872
Follow Up By: aggie - Tuesday, Jul 04, 2006 at 23:13
Thank you andrew for your reply. it has 18000kms on the clock.
FollowupID: 438205
Reply By: DiD 05 Paj - Tuesday, Jul 04, 2006 at 23:20
18000 or 180000 kms ?????
AnswerID: 181879
Reply By: aggie - Tuesday, Jul 04, 2006 at 23:35
sorry guys itwas 180,000kms
AnswerID: 181883
Reply By: Member - Oldplodder (QLD) - Wednesday, Jul 05, 2006 at 07:31
96 pajero (manual) 2.8l TD with 265,000k. Is yours the 3.0l or 3.5l?
The 3.5l petrol has a slightly heavier gear box and drive train than the 3.0l, but have'nt heard of any problems on either.
Used for various towing duties such as trailer (750kg) caravan (1200kg) and trailer sailor (2200kg).
Clutch replaced once at 140,000k, about 3/4 worn, but big trip was coming up so did it just in case. Have had heavy duty clutch put in and still going strong 125,000k later.
No problems towing or with the clutch. I just try not slip it too much and cook it. Hardly notice the trailer or caravan there. With the boat at a local set of traffic lights where it is a steep takeoff I sometimes drop it into low range until I get to the other side of the traffic lights, stop and change up again. Same on a steep boat ramp.
AnswerID: 181897
