FJ40 Handbrake
Submitted: Friday, Jul 14, 2006 at 19:05
ThreadID: 35833 Views:3566 Replies:2 FollowUps:1
Hi guys,
Just wanting to comfirm wether a rumour i heard is true...
1. Is the handbrake on an FJ40 a transmission lock or does it just activate rear drum brakes? (I found this very hard to believe)
2. How is the handbreak adjusted (someone said that you had to adjust saying in the gear box (since it was apparently a transmission lock)
Justin
Reply By: Member - Phil G (SA) - Friday, Jul 14, 2006 at 20:27
Justin,
The earlier LandCruisers had the handbrake on the rear of the transmission tunnel. It just had two shoes and a drum, and wasn't very effective.
The handbrake on your 60series works on the rear drum brakes. It is self-adjusting, which means that it will automatically adjust up whenever you apply the brakes while reversing. They can occasionally malfunction and overtighten - usually when you're doing steep tracks. If you hear a sqealing from the rear brakes when they are not applied, then you probably have this problem, and need to get a pair of screwdrivers in the adjusting hole to back them off.
And of course they can be manually adjusted too.
phil
AnswerID: 183536
Reply By: Sarg - Friday, Jul 14, 2006 at 21:13
Yes , it is on the back of the transmission.. It is effective as a park brake by not being subject to the mud.dirt,dust etc as a "drum in disc", as most of the newer systems are, therefore giving a longer, trouble free service life. As long as both rear wheels are in contact with the ground, it will hold the vehicle.
Adjustment is the same as a normal drum brake, ie, a knurled wheel turned thru a slot in the backing plate.
AnswerID: 183542
Follow Up By: Marn - Saturday, Jul 15, 2006 at 17:28
The park brake shoes on our work 78s wont last the 2 weeks between services. They are poorly designed and in my situation are not to be trusted
FollowupID: 440273
