Engine Oil's
Submitted: Saturday, Jul 15, 2006 at 11:51
ThreadID: 35850 Views:2150 Replies:5 FollowUps:3
G’day folks, tried searching the archives but with little success (prolly just me)
Question: what engine oils do you find are best for the 4.2 GU Diesel?
Reply By: 120scruiser (NSW) - Saturday, Jul 15, 2006 at 13:21
Can't go wrong with a good quality 15w/40.
Get the latest generation ie:- SL Grade.
Oils are graded in the letters of the alphabet such as SF, SG, SH, SJ and the current one is SL for mineral grade oils.
You can get SM but that is starting to get into synthetic and semi synthetic.
120scruiser
AnswerID: 183606
Reply By: Sarg - Saturday, Jul 15, 2006 at 15:48
Better off going with an oil that has high 'C' rating. S= spark ignition ie petrol. C= compression ignition ie diesel
AnswerID: 183627
Follow Up By: Brett_B - Saturday, Jul 15, 2006 at 18:52
Sarg is right anything "C" is suited more to the diesel (soot protection etc) - check your owners manual
I use C-I, but mine snot a 4.2
FollowupID: 440285
Follow Up By: 120scruiser (NSW) - Saturday, Jul 15, 2006 at 19:55
You are both correct.
Most oils are rated for petrol or light diesels.
They say SL - CI4 rated.
FollowupID: 440291
Reply By: feral - Saturday, Jul 15, 2006 at 17:39
How about this...do a google and get onto the manufacturers websites. All the quality oil makers have lub guides on the internet. Just pick your quality preference oil maker and then the guide would give you the proper oil recommendation for all components.
This eliminates the 'some mates, mates uses blah, blah oil.
Why is my engine stuffed is usually a appropriate response.
Cheers.
AnswerID: 183640
Reply By: Keith_A (Qld) - Saturday, Jul 15, 2006 at 22:33
Nissan recommend 3000ppm calcium in the oil.
'Calcium based detergents keep the engine clean particularly around the ring glands.... are also very thermally stable and as a side benefit ...a strong bearing passifying ability'.
Perhaps, being an old technology engine, the TD42 produces more carbon soot than the newer engines. The Calcium helps both clean the carbon from the surfaces, and hold it in suspension.
Here are a few oils that meet Nissans spec :
Caltex CXJ; Penrite HPR Diesel 15 (Semi Synthetic); Shell Rimula-X; Castrol J-Max;
Check out the Nissan Patrol Forums for more info......Regards....Keith
AnswerID: 183692
Follow Up By: Russell from Synforce Lubricants - Sunday, Jul 16, 2006 at 18:38
hey.... AND Synforce
FollowupID: 440422
Reply By: Gmouse - Sunday, Jul 16, 2006 at 09:29
Thanks for your replies much appreciated
AnswerID: 183725
