My 100 TD auto has got the SHUDDERS - it feels expensive !
Submitted: Saturday, Jul 15, 2006 at 19:13
ThreadID: 35861 Views:3221 Replies:9 FollowUps:9
When I sit at the lights on an incline and I just edge ahead a bit , the car starts shuddering forward . If I accelerate off from the lights I have no problems - it is only creeping forward up a slight hill .
Does anybody have ant ideas about what might be causing this .
Thanks a lot ,
Willie .
Reply By: Max - Sydney - Saturday, Jul 15, 2006 at 20:52
First thought - turn on the aircon and see if it goes away with a few more revs. If so, up the idle speed a bit.
Not something stupid like a blocked air or fuel filter by any chance?
How long since the auto has been serviced? Does it need new oil or a bands adjustment??
Happy hunting - hope you find a littlie.
Max
AnswerID: 183672
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:05
Hi Max ,
I was driving it home from a service at ARB . They were told about it and noticed it when they test drove it , but did not have time to check further and could not guess what was causing it .
I think it would be best to take it to an auto gearbox specialist if it turns out , that that is the problem .
But how do I figure out what the problem is ?
Thanks ,
Willie .
FollowupID: 440356
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Sunday, Jul 16, 2006 at 07:07
Willie,if it is manual could be a crutch thing,maybe adjustment ,Bob.
AnswerID: 183709
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:06
Bob ,
It's an auto .
Willie .
FollowupID: 440357
Reply By: Toytruck - Sunday, Jul 16, 2006 at 08:35
Willie,
I have seen many discussions on this subject on this forum about the same problem. I have a shudder in my 10 series also. Most comments are always directed towards teh clutch, in manual vehicle obviously. One thought that did go through my mind, and I may be wrong, what about the clutches in the LSD. If these were not correctly set it would cause a "shudder" that would almost certainly feel like a clutch shudder.
Could be way off the the mark but just a thought.
Toytruck
AnswerID: 183716
Follow Up By: Member - Willie , Epping .Syd. - Sunday, Jul 16, 2006 at 11:09
Thanks ,
I am an idiot at things mechanical . It did not know it had a LSD . It has diff locks though and these have just been serviced also .
Thanks ,
Willie .
FollowupID: 440358
Follow Up By: Toytruck - Monday, Jul 17, 2006 at 20:36
Willie,
I rekon the diff lock would remove any question about the clutches in the LSD as the new diff center would remove the LSD clutches. It seems most of the other posts have some pretty good advise around the auto trans.
Was a good guess though....I thought.
Toytruck
FollowupID: 440611
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Sunday, Jul 16, 2006 at 11:19
Ah, there in lies you're problem,sounds like you/ it may need servicing after you're out back tour.
Bob.
AnswerID: 183742
Reply By: Member - mikeyandmary (NSW) - Sunday, Jul 16, 2006 at 16:18
We had to replace 2 gearboxes in auto cars (before we came to our senses and bought a toyota). The shuddering you describe sounds like what both cars did before the gearbox died. (Ours cost $2500 each only 2 months before our wedding!!!)
Get it checked by a auto transmission shop. If it is the gearbox it will be hopefully cheaper to fix before it craps itself. If its not the gearbox then at least the box has had a service and you know to keep looking.
Hope it's easy to fix...
AnswerID: 183769
Follow Up By: Member - Willie , Epping .Syd. - Monday, Jul 17, 2006 at 13:36
M & M ,
Yes , an auto service and "going over" is the answer I think .
Thanks ,
Willie .
FollowupID: 440537
Reply By: Brew69(SA) - Sunday, Jul 16, 2006 at 16:23
Impossible!!!!!!!!!!!! These things don't go wrong with Slowotas! Should have got a Patrol. :)
AnswerID: 183770
Follow Up By: Member - Willie , Epping .Syd. - Monday, Jul 17, 2006 at 13:33
I was going to get a Patrol , but because I do a lot of trips in the hot climate I felt all the plastic might melt .
Willie .
FollowupID: 440533
Reply By: sdr00y - Sunday, Jul 16, 2006 at 21:18
Willie, try the transmission physician at hornsby.
sdr00y
SD
AnswerID: 183833
Follow Up By: Member - Willie , Epping .Syd. - Monday, Jul 17, 2006 at 13:31
Thanks for the tip . I will give them a ring .
Willie
FollowupID: 440532
Reply By: Redback - Monday, Jul 17, 2006 at 09:19
What about the uni joints Willie my Disco had a similar problem, when the Double Cardan joint went.
Baz.
AnswerID: 183865
Follow Up By: Member - Willie , Epping .Syd. - Monday, Jul 17, 2006 at 13:34
Baz ,
OK , I will suggest they check that.
Thanks ,
Willie .
FollowupID: 440534
Reply By: gazza60 - Monday, Jul 17, 2006 at 12:00
sounds like the torque converter might have problems
AnswerID: 183886
Gazza ,
I will also ask them to check that out .
Thanks ,
Willie .
FollowupID: 440536
