Replacement Bumper/Wheel carrier 105 series
Submitted: Sunday, Jul 23, 2006 at 11:53
ThreadID: 36084 Views:2325 Replies:2 FollowUps:3
About to outlay some serious dosh for the above,want a complete replacement bumper with duell pivots.
Just want to know what brands people are useing,have seen the new ARB bar but not to keen on the styling,quite fond of the Kaymar design but what are the 4WD systems ones like , likewise the O/L carriers.Any others??
Reply By: SmithyWA - Sunday, Jul 23, 2006 at 12:46
K&N in Canningvale are another option you should consider.
Smithy
AnswerID: 184888
Follow Up By: Member - Matt- Sunday, Jul 23, 2006 at 14:07
I'll second that.
matt
FollowupID: 441610
Follow Up By: Member - Nick (Kununurra) - Sunday, Jul 23, 2006 at 16:44
Do you guys have any contacts for them??
FollowupID: 441627
Follow Up By: Member - Matt- Sunday, Jul 23, 2006 at 18:00
try www.kn4wd.com
Have one on the GU, good solid bit of gear
cheers, Matt
FollowupID: 441637
Reply By: Mikee5 (QLD) - Sunday, Jul 23, 2006 at 20:51
Hi Nick,
I have just bought the one made by TJM. I had to get this on as neither ARB nor Kaymar will fit the Standard 105 series because of the barn doors. I fitted it myself and the instructions were not bad. One issue was that the laser cut slots for the bolts which hold the wheel mount to the pivoting arm did not line up, the mount was exchanged as a warranty item no arguements. I am only 20 mins from the dealer, could be upsetting in Kununura. The bar is rock solid and has hi lift jacking points built in. The original towbar did not have to be removed during fitting and sits neatly underneath.
AnswerID: 184930
