gu patrol electric fuel pump..
Submitted: Monday, Jul 24, 2006 at 21:40
cainy
in regards to the post number 35664. i have a gu 2.8 and have fitted
fuel flo electric pump. There is a good noticable increase throttle responce. Acceleration is a lot better too. On the high way it performs better and dosnt use as much boost, so the economy has improved also. over all it was a great mod. when i fitted the pump i put it after the
fuel filter, this was done because the pump has a built in 50 micron filter but it is a sealed pump. not sure how u would go if it got clogged up..
Reply By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 12:59
What sort of $ are the pumps worth. After reading the post on the 3.0l pump going, I might plumb in a pump down near the
fuel tank and put a CAV filter in somewhere. I think the 2.8 has it's
fuel return hose going into the filter not into the
tank, (I was once told this is not good, as the pump heats the
fuel a bit, and if it keeps circulating it will get warmer and warmer, compared with being allowed to cool a bit in the main
tank). Does anyone think this will be a problem if I fit an electric pump down near the tanks which in this case will not have any pressure release! (apart from the
fuel the car is using)
Cheers Andrew
185220
Follow Up By: Flash - Tuesday, Jul 25, 2006 at 14:23
I've been running an electric pump ("Facet" brand with output about 5psi) near the
tank for years now.... and a Frantz (
toilet roll)
fuel filter for many years on my TD42.
Outstanding results, and the
toilet roll filter has to be the perfect filter filtering down literally to a micron or two. (it's upstream of the factory filter, which never sees any dirt at all.)
441975
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 14:28
Does the 4.2 return
fuel to the
tank or back to the filter? I might do google on the Facet
Cheers Andrew
441978
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 14:56
Andrew,
Return is back to the
tank. I too have a Facet pump fitted recently. They're about $80- to $100- and only push about 3 to 5 psi.
Roachie
441983
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 15:15
Looking at a website & they have a pressure relief valve so the
fuel return may not be a problem for me.......just how noisey are they & what model did you get
Cheers Andrew
441987
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 16:24
The one I got is a 594 from memory. I've fitted it to the side of the chassis rail, right under where I sit. It is mounted on rubber buffers and I can just barely hear it before I crank the engine over (waiting for the glow plugs to do their trick). After start up, no can hear at all.
442010
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 25, 2006 at 16:33
Sorry....it's a 574.
Check out Post number 34,343 for some more info. Also, type in "Facet" to the search at the top of the
Forum page and you'll get a lot of info.
442012
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 16:41
Thanks for the info, I'll do a bit of searching around
Cheers Andrew
442016
Follow Up By: Member - andrew B (Kununurra) - Tuesday, Jul 25, 2006 at 17:50
Bit of searching around, $100.00 delivered to KNX. Will check the locals tomorrow to see if they have anything similar priced.
Thanks for the advice
Andrew
442042
