Cost of galvanising
Submitted: Friday, Jul 28, 2006 at 20:47
Farside
Does anyone have a rough idea on the cost of getting a box trailer galvanised? I am about to start welding the frame together and would like a guide before I ring up for a quote.
Angus
Reply By: black bull - Friday, Jul 28, 2006 at 21:09
hi angus, last time i inquired about galvanising not long ago it was about 1.30 a kilo
in
newcastle hope this helps deano
185907
Follow Up By: Member - Ian H (NSW) - Friday, Jul 28, 2006 at 21:54
You will get a bit of buckling in the metal due to the heat involved but mainly will be in the floor sheeting.
442851
Reply By: D-Jack - Friday, Jul 28, 2006 at 21:59
Price quoted for me for a 7x4 box trailer was about $900, plus the engineer wanted an extra $400 because of the extra time involved drilling/grinding out the galv from where it wasn't wanted. Dunno if this was overkill or not or if he was trying to discourage me from getting it galved, but the rest of the trailer was a good price. There have been threads I believe on whether or not Galvanising makes the chassis more brittle and prone to cracking.
D-Jack
185912
Reply By: Member No 1- Saturday, Jul 29, 2006 at 11:15
if made of square steel you will need to drill holes in any or all section that are, so that there is not the possibilty of having moisture trapped...big boom if there was
185966
Reply By: 1KZ-Mick - Saturday, Jul 29, 2006 at 18:39
Angus,
Korvest in
Adelaide charge $1 per kilo.(weight of the object being dipped not the galv) Also bath sizes vary between galvanisers so check that they will be able to handle your trailer size.
Mick.
186007
Reply By: hoyks - Saturday, Jul 29, 2006 at 19:00
I dropped into the industrial galvanisers on Maitland rd at Hexham and was quoted $250 for a 7x 4 trailer. Basically $1/kg. You will have to drill some big holes in the bottom of all the RHS sections so the gal can get in and drain back out again, looking at about 2/3 the width of the section.
186009
