Nissan SD33T engine info/problems?
Submitted: Monday, Mar 03, 2003 at 12:40
ThreadID: 3626 Views:12561 Replies:2 FollowUps:0
Hi folks, just did a search looking for info on the Nissan 3.3 L
Turbo diesel (SD33T) engine but came back with very little. Does any one have any experience with this engine? what to look out for when
buying one. The one I am looking at also has an aftermarket
intercooler on it and switchable 7 / 10 pound boost controller.
Reply By: desert - Monday, Mar 03, 2003 at 21:21
A very reliable and robust engine that makes good power and torque for it's vintage. Oil change intervals are important due to the 4-main bearing crankshaft. I would suggest an after market by-pass filter/purifier such as a Franz. The oil pressure switch has a low-pressure cut out circuit that will shut down the engine if oil pressure falls below 8psi(I think), this safe guard mechanism can cause intermittant problems if water/crap gets inside the protective boot around the sender. Fuel inlet hose into the fuel injection pump has a sintered bronze filter in-line. This can clog up and cause lack of power/failure to rev over 1500rpm/surging problems. Other than this, it is a bomb proof engine. I ran a brand new MK (1985 turbo) from Melb to Brisbane in summer, fully laden, air con all the way, sat on 120kph and it still returned 29 mpg!
AnswerID: 14372
Reply By: Robo - Tuesday, Mar 04, 2003 at 08:40
Thanks Desert, some very helpfull info..
AnswerID: 14402
