Aux petrol tank for LPG GU Patrol - how many litres?
Submitted: Monday, Jul 31, 2006 at 22:36
ThreadID: 36341 Views:8287 Replies:7 FollowUps:6
Hi all,
I have a 98 GU Patrol wagon, 4500 petrol, that I'm looking to put on LPG. Apparently the std practice is to remove the main petrol tank to put the LPG tank in, and then either keep the (pitifully small - 36 litre) subtank for petrol, or take it out as well and install a bigger aftermarket tank in its place. To all of you who've been through this exercise -
a) Has anyone come up with a gas installation that retains the nice big 95 litre main petrol tank?
b) Alternatively, what size aftermarket tank do you have to replace the subtank?
c) How much lpg do you get into the lpg tank?
Thanks!
Tim Zylstra
Tanna Island, Vanuatu (for only a little while longer)
Very dodgy 2.8 diesel 4Runner, in Tanna
98 GU Patrol, back in Oz
Reply By: 1arm - Monday, Jul 31, 2006 at 23:26
G day tim
My GU 4.5 was already fitted with gas when i bought it and has a 120lt gas tank and the 30lt approx petrol tank.
Mine takes 88 lts of gas when empty.
As for the first 2 questions cant help you sorry.
Evan
AnswerID: 186414
Reply By: gqpat - Tuesday, Aug 01, 2006 at 08:55
a) NO
b) many after market usally around 80 ltrs
c) D90 tank 115 water capacity 90 ltr usable
AnswerID: 186445
Reply By: adamj1300 - Tuesday, Aug 01, 2006 at 10:53
pull out one of the 3rd row seats & place the tank in the rear of the car?
AnswerID: 186475
Follow Up By: Leroy - Tuesday, Aug 01, 2006 at 11:14
takes up valuable cargo space!
Leroy
FollowupID: 443523
Follow Up By: adamj1300 - Tuesday, Aug 01, 2006 at 11:15
true but where alse can the tank go?
FollowupID: 443524
Follow Up By: Truckster (Vic) - Tuesday, Aug 01, 2006 at 15:51
where the main tank is
FollowupID: 443581
Follow Up By: Truckster (Vic) - Tuesday, Aug 01, 2006 at 15:52
PS... who would want an LPG tank INSIDE their car that big..
FollowupID: 443582
Follow Up By: zigglemeister - Wednesday, Aug 02, 2006 at 07:47
Hehehe,
Thanks guys, but the reason I have a Patrol and not something smaller is my five kids... although, I suppose it might be quieter if I left a couple at home!
Tim
FollowupID: 443704
Reply By: flappa - Tuesday, Aug 01, 2006 at 11:32
Recently converted my 4.5 Patrol.
Replaced the Subtank with a 72l petrol tank , and has a 100l LPG tank.
A couple of guys have gone with an 80l petrol tank.
You can fill a Gas tank to 80% capacity to allow for expansion.
It IS possible to add more , but you would want to be about to use it (trip etc) to allow for any expansion.
AnswerID: 186479
Reply By: Member - andrew B (Kununurra) - Tuesday, Aug 01, 2006 at 13:37
The mob that fits the lpg to the diesels puts a 28l useable gas tank opposite the factory sub, after modifying the exhaust. I have often wondered how expensive it would be to get a new exhaust, routed away from the area, and maybe fit another sub tank there. Possibilities of an aftermarket 70 odd litre one for about $700.00, or a std 30 litre one for a lot less(???).
I suppose the 3rd option is a custom tank, There is a fair ammount of room under there if you ripped the lot out (exhaust, petrol tanks etc), and find the biggest tanks that could be fitted into the space you have created.
Cheers Andrew
AnswerID: 186500
Reply By: Neil - Tuesday, Aug 01, 2006 at 21:06
Gday Tim
Have been through the experience, we have a 2001 GU,and when we bought it iwe converted it to gas, cost was $3000, they replaced the main tank with a 90 litre gas tank which holds approx 86ltrs, and they replace the sub tank with a 80ltr fuel tank. Its easy to use as all you do is push a button to change from gas to petrol, fuel comsumption is pretty high, at around 350km to 86ltrs, which drops dramatically when towing a load, but hey we all know there gonna chew the juice, the compromise you take when having four kids...when on the open road on gas and towing the engine works a little harder trying to keep a constant speed, but for around the town, and not loaded it doesnt work much at all. we run a set of 270/70R16, and a full carry rack, all adding to the load.
It cost around $45 to fill on gas, and the unleaded about $100, Im happy with the conversion, and have had no problems with it since installed about a year ago, if any thing it probably detuned the engine a tad when running on unleaded, but in all has been good value.
Good luck in making the decision
Neil and Lea
AnswerID: 186595
Follow Up By: Kata - Tuesday, Aug 01, 2006 at 23:24
A mate of mine used to have a 99 4.5lt Patrol till about a year ago and that was also on dual fuel and it am sure when we used to go away would take around 80lt of petrol and similar amount or more gas.
Can ask him 2moro if you want to know 100%
Kata
FollowupID: 443684
Reply By: zigglemeister - Wednesday, Aug 02, 2006 at 07:50
Thanks everyone,
Looks like around 80 litres or so replacement petrol tank will be the go!
Tim
AnswerID: 186656
