Long range fuel tank - Mazda E2000
Submitted: Wednesday, Aug 02, 2006 at 16:35
ThreadID: 36390 Views:3719 Replies:1 FollowUps:3
I've got a Mazda E2000 motorhome (started life as a LWB flat-bed) and I'm looking to get an auxilliary fuel tank installed before heading off on a big trip around Oz :-) The thing is, I'm struggling to find anybody locally (Brisbane) who can / will fit one.
The nearest I got was ARB and Opposite Lock who said there was a tank for this vehicle but not to fit a pre-1992 model. Does anybody know of a tank for this model or a generic one that can be fitted?
My last resort is to build a bracket underneath the van to carry a couple of jerry cans but I'd rather not do this if possible.
Cheers.
Reply By: kev.h - Wednesday, Aug 02, 2006 at 17:30
Hi do you have room to fit a second standard tank or does the motor home come down lower than the chassie if you have room i have a tank that should fit i had if under a ford econovan e2200 flat bed
Kev
AnswerID: 186760
Follow Up By: wmoore - Wednesday, Aug 02, 2006 at 19:18
There is lots of room under the chassis - the motorhome skin hangs down over the chassis but apart from the spare wheel there is plenty of room underneath. We have a waste water tank behind the main fuel tank and the house electrics are on the other side. But I think we should be able to mount another tank back there.
Where abouts are you? The Ford Econovan and the Mazda are basically one and the same aren't they?
FollowupID: 443839
Follow Up By: kev.h - Thursday, Aug 03, 2006 at 16:56
I'm in Bundaberg the tank is approx 330mmx330mmx870mm with a mounting flange each end on the centre line overall (outside flanges )is 930mm it has a gauge sender filler neck suction line and breather - it needs a small electric fuel transfer pump
if it looks like it will fit give me an email address and i can send you some photo's
Regards kev
FollowupID: 444077
Follow Up By: wmoore - Thursday, Aug 03, 2006 at 20:35
The van's out getting some welding done just now so I can't measure but I'd appreciate the pics and I'll check it at the weekend.
waynemoore[at]aapt.net.au
FollowupID: 444124
