does this sound ok?
Submitted: Thursday, Aug 03, 2006 at 11:08
ThreadID: 36407 Views:2459 Replies:3 FollowUps:18
just rang telstra to set up internet with the mobile and laptop and said that it's cost $29 for 15 mb, my plan wouldnt allow me to do the $29 for 10 hrs. and then its $2.05 for every 1mb over that we use......does this sound good.....we would only be using it to do the banking and email every now and then....
Laura
Reply By: Rokkitt - Thursday, Aug 03, 2006 at 11:24
Hey,
Personally I don't like the products Telstra sells....the last time I used there internet service they had a policy which stated "you get diconnected every two hours" - a while ago I dealt with telstra ion behalf of a corporate customer, what a difference in service!
Try Exetel
AnswerID: 186896
Follow Up By: Laura B - Thursday, Aug 03, 2006 at 11:26
with exetel for internet but telstra for the mobile.....can exetel do the internet off the mobile for while we are away???
Laura
FollowupID: 443978
Follow Up By: Motherhen - Thursday, Aug 03, 2006 at 23:34
Probably just as well you get disconnected every two hours - we met someone with mobile internet through the bigpong, and when their mobile connection dropped out due to erratic reception, they couldn't log out and the bill kept on running up even though they weren't connected. Got a bill for thousands $$$s when they got back to civilisation. Apparently there was an obscure place they could have tick to enable auto log off 20 minutes after disconnection.
FollowupID: 444168
Follow Up By: Member - Mike DID - Friday, Aug 04, 2006 at 16:25
I'd be talking to Dept of Fair Trading about being charged for a service when it was not being provided i.e after call dropping out. That billing system is defective !
FollowupID: 444313
Reply By: Member - MrBitchi (QLD) - Thursday, Aug 03, 2006 at 11:42
Do you really need your own account? Can you get by with using internat cafe's? The mobile data rates are a rip off. $29 for 15M? My cable plan gets 6GB for not much more then that....
You can easily set up a system on a USB key using Portable Apps that you can use on anyones PC and leave no traces behind. Perfect for banking and email. All your data is stored on the USB key. Just use Synctoy or similar to back it up onto your laptop.
AnswerID: 186900
Follow Up By: Rokkitt - Thursday, Aug 03, 2006 at 11:58
I have a vodaphone data plan - $30:00 for 100Mb, there are other plans available up to $100:00 per month for 1Gb....I have never gone over the 100Mb.
Not sure if exetel have a similar plan....just give them a call!
Rod
FollowupID: 443990
Follow Up By: Rosco - Qld - Thursday, Aug 03, 2006 at 14:33
Be aware tho, that Firefox is not always compatible with internet banking.
Certainly isn't with St Geo
FollowupID: 444030
Follow Up By: Member - MrBitchi (QLD) - Thursday, Aug 03, 2006 at 14:51
Would need to be tested first, but works fine with Citibank, Virgin, Bank of Qld, Amex, ING...........
FollowupID: 444034
Follow Up By: disco1942 - Thursday, Aug 03, 2006 at 14:52
I use firefox with St George. A while ago I could not use Netscape as Sun Java was not compatible with the non- standard M$ Java. St George has now come into line and is now using industry standards. Install JRE on your Firefox and allow St George to use it and you will be right.
FollowupID: 444036
Follow Up By: Rosco - Qld - Thursday, Aug 03, 2006 at 14:59
JRE ??
As that certain readhead once said .... please explain?
FollowupID: 444038
Follow Up By: Member - MrBitchi (QLD) - Thursday, Aug 03, 2006 at 15:21
JRE... Java Runtime Environment
If you install the latest firefox that should be all you need to do. If not, download the latest Java from Sun.com
FollowupID: 444044
Follow Up By: Rokkitt - Thursday, Aug 03, 2006 at 18:01
Laura,
Sorry to repeat myself but just thought I should clarify what I said...I use Exetel for a home connection, not sure if they have a mobile service - I am already in a contract with Vodafone for there datacard.....
Vodafone review
The mobile connection holds for up to 15 minutes, find a good spot to connect and stay there while you do what you have to. Think most phone companies have a similar product and cheaper than the phone plans I found.
Funny thing is I get to work while I am on Fraser Island because of it, couldn't ask for a better work enviroment though....:)
Rod
FollowupID: 444097
Follow Up By: Member - Tim - Friday, Aug 04, 2006 at 01:01
You should be extremely cautious using an internet cafe for your internet banking. This is one of the easiest ways for your passwords to be stolen. You have no idea what key logging and data logging programs are running on that kind of system. In many cases the owners of the cafe have no idea either but there have been cases where they were actually involved in the scam to steal passwords. All it needs though is for the last person using the PC to have loaded a trojan program.
It's less of a risk if your financial institution has some extra level of security such as password tokens but still a risk.
Tim.
FollowupID: 444173
Follow Up By: Member - MrBitchi (QLD) - Friday, Aug 04, 2006 at 08:16
Understand your caution, Tim, but please show me one single documented case of someones banking details being stolen due to a key logger running on an Internet Cafe's computer....
Right up there with "Got this warning via email from Microsoft about .........."
FollowupID: 444186
Follow Up By: Laura B - Friday, Aug 04, 2006 at 10:08
i was only going to do it because of the banking that needs to get done but i have run my mother through it and she is going to do it for me....!!! Will use cafes for emails though....
Laura
FollowupID: 444202
Follow Up By: Member - Tim - Friday, Aug 04, 2006 at 13:10
Hi John (Mr Bitchi),
It is not just my caution and there are documented cases. Unfortunately I have so much stuff relating to security of Internet Banking that I haven't been able to find the references to the actual case I know of in a short space of time. I have this information because in my other life off this forum I am involved on the side of providing internet banking services.
I will keep looking and see if I can find actual documented cases since you are right that is the only proof rather than what I might say.
In the meantime every single internet banking site that I know of has some security recommendations on them. Take their word if you don't trust mine :). I have just had a look at the Westpac one and it recommends ringing them and changing your password straight after using a public computer. But it also suggest using telephone banking as an alternative. Same sort of warning on all the others.
It has always been easier to steal information from the end user than it has been to attack the actual internet banking site. The security at your end can only be assured on a computer that you control, not on a public one. Your virus protection and firewalls etc don't travel with you to a public computer. They are perfect for things that you don't mind being public like looking for information about things but I would not trust them to keep private information private.
Oh well, down off the soapbox. If you do get you money stolen John you will probably be ok since the banks will probably cover it for you even if it is your fault. Very nice of their insurance companies don't you think?
Tim.
FollowupID: 444236
Follow Up By: Member - Tim - Friday, Aug 04, 2006 at 14:41
Ok, I have managed to find a news story on the prosecution that I was initially talking about. If you follow this link you will read a news story about an owner of a chain of internet cafes who was logging all passwords.
www.castlecops.com/article2568.html
Fortunately he got caught, but I will say again - the problem with public terminals is that you have no idea what programs have been loaded on that machine before you got there.
Most of the information about how hackers got hold of an end users password is not publicly available as it is usually the result of internal investigations. A lot is by the method described in Roachie's recent post of getting the user to log into a fraudulent site but key logging programs delivered via e-mail and online chat are also prevalent.
All the efforts for security on the side of the banks and other financial institutions are good, and you as consumers should be insisting that your FI provides you with the best, but a lot of responsibility lies with the user to protect the equipment used for access.
Tim.
FollowupID: 444267
Follow Up By: Member - MrBitchi (QLD) - Friday, Aug 04, 2006 at 14:56
Most (all the ones I use) banks require you to enter your login details using your mouse, a method that defeats keyloggers.
Most internet banking fraud is accomplished by Phishing or 419 scams.
Be wary, not Paranoid.
FollowupID: 444273
Follow Up By: Member - Tim - Friday, Aug 04, 2006 at 15:12
Hi John,
It defeats some of the key loggers. There are others that will record mouse clicks and some will even capture screen shots of what you are doing. We only ever play catch up games with the hackers.
Have you ever thought about the issue of a camera that might be looking over your shoulder? There are many ways, some of them very simple. People are still discovering new ways to hack ATM's that are wonderfully creative but driving a truck into one still works.
It is not paranoid to avoid public computers for internet banking. On your own computer you can control your environment and can do all the things necessary to be comfortable about your security. I am not in any way saying that you should not use internet banking as it is as safe as a credit card when used properly. All I am saying is that it is not safe to use a computer that you don't control.
Tim.
FollowupID: 444280
Reply By: bruce - Thursday, Aug 03, 2006 at 12:34
If you are on a dial up plan with an ISP that has a 0198 number...it is very easy to set that up on a lap top and dial in from anywhere in the country that you can get a dial tone and for the cost of a local call and no limits at all....cheers
AnswerID: 186911
Follow Up By: Member - Oldplodder (QLD) - Friday, Aug 04, 2006 at 07:56
Works well for me too.
FollowupID: 444182
