alternate to second battery???
Submitted: Monday, Mar 03, 2003 at 21:10
PETER
think a waeco 12volt&240 volt thumper will suit me better than a second battery in my pajero nm due space and portability. rays outdoor do not stock larg thumper only smaller model where i
shop and they seem to have best price as on the thumper small 659 rrp they give 6.5 off with discount card ant 20% when on special. the one i want is 1199 rrp so discount most important - any body any ideas - better option - better price . thanks for any assistance regards peter
Reply By: Frank - Monday, Mar 03, 2003 at 21:50
Peter,
Check out the site below.
http://www.fridgeshop.com.au/remotearea.html
Waeco - Monsoon
Product Code RAPS400
Voltage 48 amp Hour
Price $699.00
Weight 16.4 kg
Capacity 1200 amp cranking capacity
Quality Features Full LED Display, 2 x 15 amps Hella Outputs, 1 cross over switch 24-48 amp hours.
Appox Running Times 55 watt spot light 10.5 Hrs, 12 volt fridge 45 hrs,1 versalite 48 hrs
Warranty 1 Year
14379
Reply By: Spanner - Monday, Mar 03, 2003 at 22:07
Maybe check out Battery World or someone like that. These things are mostly Sealed Leadacid Batteries in an expensive, but convenient box with all sorts of connectors on it. BWorld might be able to supply the batteries and a charger much cheaper without the fancy box. Of course, there would be cheaper
places than battery world too. I probably don't need to remind you to make sure whatever you get is tied down very securely if it's in the cabin, even behind a cargo barrier.
14382
Reply By: Rick - Monday, Mar 03, 2003 at 22:55
Peter,
I have used a similar set up for several years and am a 'happy camper'.
I have a GU Patrol petrol, and know that after running lights & fridge off the remote battery, there will be enough oomph to start the vehicle in the following morning, should it be necessary. Of course, the battery is recharged by the next day's travel, or it can easily run lights etc for several nights if not recharged.
And the ability to take the battery to the
campsite, (portability in your vernacular) away from the vehicle, was a major deciding factor for me. Having 12 V fluoro lights at the cooking/
campsite, without having the vehicle within 6 metres, is a significant enhancement for our way of
camping & touring.
Another reason I went this way is price; that is, I did not have to pay for all the switches/relays/installation/battery trayetc. And I can retain the air compressor under the bonnett - this space would be sacrificed if I had a second battery under there.
Do it - buy it - but first calculate your draw (radios, fridges, lights, efficiency loss factor, etc) so that you can establish what amp hours are needed, and hence the model you need.
Rick
14387
Follow Up By: Phil P - Tuesday, Mar 04, 2003 at 05:56
Hi Rick,
Can you please supply more details about what sort of battery, charger etc that you are using ?
Phil P
8653
Reply By: David - Tuesday, Mar 04, 2003 at 11:09
The Thumpers are OK but you are paying top dollar. There are other alternatives which are better value for your hard earned dollar.
14407
Reply By: paul - Tuesday, Mar 04, 2003 at 11:33
I'm with Rick, sort of.
But i have two batteries, one a 33amp hour AGM battery i use for lights and music.
I then have an optima deep cycle yellow top i wire directly to the fridge. I like the optima for that fact that due to its construction i can recharge it at up to 45amps per hour which means i don't have to drive around all day to recharge it and i have other ways to do that anyhow.
I just love the portability. I also have my collection of
inverters and connectors and plugs, kind of low grade hobby.
14410
Follow Up By: Member - Rohan K - Tuesday, Mar 04, 2003 at 13:50
Paul, can you describe your set up in more detail. I'm interested in any alternatives to both an underbonnet dual system and the Waeco style. I think both are too expensive and neither is ideal - the dual system lacks "portability" but the Waeco lacks capacity (especially for the $$$'s).
Rohan
8675
Reply By: AK - Tuesday, Mar 04, 2003 at 22:00
Make your own and save the $. I have just finished wiring a solenoid from the battery in the engine bay to a 50A Anderson plug under the front
seat. I then put a sealed deep cycle battery into a battery box with a small lead on it and the other end of the Anderson plug, the battery box also has 2 female hella plugs mounted on top via seperate fuses 1 for the fridge and 1 for the lights. The system work like this most days the battery box sits in the garage but when going bush I strap it behind the front
seat and plug it in . All up it cost about $300 or so including the battery which is 75A /hr compared to the 24a Waeco.The good thing about this set up is I have the best of both worlds ie dual battery system plus a portable power pack.
AK
14451
Reply By: GaryInOz - Tuesday, Mar 11, 2003 at 20:48
Another battery worth a look at is an "Odyssey":
http://www.odysseybatteries.com.au/odyssey/technical.htm
Just the battery so you would have to organise a way of connecting it all up but the most expensive (77Ah) is around the $400 mark I beieve.
14870
