Tuesday, Mar 04, 2003 at 14:48
Glad the fan job's a success
I believe I recall you're going to go intercooled-
are you going for the bonnet scoop setup or in front of the radiator
Have heard the bonnet scoop is not great at low speed (sounds logical-not much airflow) and in front of the radiator puts more heat into the radiator as the rad gets air thats already hot....
which way are you going?
Also I gather from your website you want more
fuel?
If you've got more time on your hands than $ (a fair bit of time here- took me about a full weekend) you can do it on the cheap! I did it about 10 yrs ago by adapting a Gemini
tank rolled on its side- got everything from the wreckers for stuff all$ and it works like a charm- gives me 52 litres extra. I pump from the "aux"
tank when required into the return line (into the main
tank) The original gemini
fuel sender even works on the Patrol gauge- just works with a changeover relay to read the aux
tank level whenever I'm pumping. Cost me LESS than $50 plus time, but works a treat!!
8681
