Patrol GU 2005
Submitted: Friday, Aug 04, 2006 at 16:37
anglepole
Does any one know how the door remotes control units are programmed?
Are there any suppliers of remotes than Nissan? They are about $133 from them.
Reply By: Member - Jon W (QLD) - Friday, Aug 04, 2006 at 16:54
If its any help, I had both of my remotes replaced under warranty in June. Ours is a 2003 Patrol. Both units failed after approx two years and would flatten a battery in about two weeks. Peter Kittle in AliceSprings did not hestitate to replace them under warranty.
Jon W
187135
Follow Up By: angler - Friday, Aug 04, 2006 at 21:49
It's a 2005 model,
well in warranty, why do you want them reprogramed?
The biggest problem with patrol remotes is the very severe lack of response over 4 metres away from the vehicle. Sometimes
mine requires three or four pushes before anything happens. You get used to it after a while. Nothing equals an after market setup for distance.
Pooley
444402
Reply By: sub - Friday, Aug 04, 2006 at 21:20
angle
my 02 remote died .went into a place called ashley electrical in malaga. they do all sort of remotes ,alarms etc . they said that nissan was about the only ones that they could not get any cheeper than me.they have a system that could install over the nissan system and came with 2 remotes for about $165.i still went with the nissan one for the same price as you are talking .
about 2 months later the remotes on the missus mistsubshi died took them to ashleys and they repaired them on
the spot for 10 bucks .great service
187180
