Oziexplorer - Need help
Submitted: Friday, Aug 04, 2006 at 19:24
ThreadID: 36453 Views:1812 Replies:1 FollowUps:2
Oziexplorer has a Map View window which can be switch on or off. It appears that one of my NatMap images has a corrupted Map View. all other images show the Map View without any problems.
How can I fix the Map View for this particular image.
Any suggestions would be appreciated
Reply By: The Explorer - Friday, Aug 04, 2006 at 19:45
Hello George - what exactly happens? Does it disappear when you click on map?
The problems I have had with map view in the past were, from what I could figure, related to software issues and not the actual map image or calibration file itself. This is based on the fact that the problem came and went (and came and went...).
AnswerID: 187164
Follow Up By: Member - George (WA) - Friday, Aug 04, 2006 at 19:54
Hi Greg, The Map View Image is blue with a lot of distortion, is the best I can describe it. It only happens for the NatMap image of Perth
FollowupID: 444375
Follow Up By: Member - George (WA) - Friday, Aug 04, 2006 at 19:56
Forgot to answer your other question. Yes it disappears and re-appears, when I toggle the Map View Button on the tool bar at the top
FollowupID: 444376
