285/75/16 62 Series Cruiser
Submitted: Tuesday, Aug 08, 2006 at 16:04
Ron
I'm considering changing my tyre size from 31/10.50/15 to 285/75/16. I have Old Man Emu
suspension with a 2" above standard lift in the front and a 3" above standard lift in the rear. Has anyone done this and found any faults with it, for example, too much power loss or not enough space under the guards. I'm unable to put a set on to try. Any advise welcome.
Thanks,
Ron.
Reply By: GaryInOz (Vic) - Tuesday, Aug 08, 2006 at 17:11
You are going from a 31" tyre to a 32.8". No difference in performance worth noting. ~4% difference in speedo reading, probably brings it up to around accurate, given they usually over measure by a few percent (100km/h indicated = 95 real or so)
An eyeball under the guards to see if you have enough space (ie an extra 1" or more) for clearance of the new tyres with chassis rails/steering components/
suspension components should be all you need.
The issue will be getting the offset on the rims and the width of the rims right.
187878
Reply By: boogyman - Tuesday, Aug 08, 2006 at 17:21
it should actually read5 km/h under what you are doing(100on speedo=105real) might be worth havin it callibrated just to make sure.
187880
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Aug 08, 2006 at 18:49
I have the BFG's 285/75/16 and clearance and road holding especially off road is good.
There was a power drop and
the gap in the auto is a bit big for this tyre size and you have to rev out slightly higher before gear change when towing but is otherwise a good upgrade.
187906
Reply By: Michael_FNQ - Tuesday, Aug 08, 2006 at 20:34
The perfect tyre is a 32x11.5x15 - Correct rolling diameter and only just rubs the rear inner guard on full travel
There is less tread depth on a 16 inch tyre so it will not do as many km's.
187945
Follow Up By: BRUCE G/C - Tuesday, Aug 08, 2006 at 22:31
Hi Ron, I have a hj61 and have been running 285/75/16's with no problems.The oil burner ran better with a larger tyre and got 75k wear. Dont no how you would go with petrol? Good luck anyway mate.
cheers bruce
445219
Reply By: Tony J - Wednesday, Aug 09, 2006 at 21:58
I have an 80 ('97 model) STD with 16*8 gxl rims running 285/75/16 BFG muddies. Vehicle has HHD King Coils (about 2" lift). Never had a tyre rub on any part of the car. Motor is a 1HZ with an aftermarket turbo, haven't noticed any performance drop since fitting this size tyre. By the way, the BFG web site says the 285/75/16 mud terrain to be just over 33". Speedo is about 4% inacurate: i.e. by the GPS 100kph is reading on speedo as 95-96kph.
188256
