Max air compressor
Submitted: Wednesday, Aug 09, 2006 at 09:48
GoneTroppo Member (FNQ)
After all the good reports here, and also on the recommendation of the bloke at the
shop I bought the Max air unit. $260 5 year warranty.
Had been thinking ARB as I had two for years without any problems, but the max air eats it for performance.
I was surprised to be told that ARB now own Bushranger and therefore Max Air.
Makes you wonder if we will see the ARB compressor discontinued.
For airlocker use ARB now uses a much smaller unit instead.
Reply By: ross - Wednesday, Aug 09, 2006 at 09:54
Which maxair did you get? I paid $360 for their top of the range and the next one down was $139 and then $99 for the entry level model.
Im happy with the performance. I can get all 4 x 33 ich 10.5 BFG pumped from 17 psi to 34psi in under 14 minutes
188074
Follow Up By: GoneTroppo Member (FNQ) - Wednesday, Aug 09, 2006 at 10:14
Sorry that was a typo, it was $360.
BTW thay had the Lion brand knockoff for $260 there.
Did you mount yours permanantly or do you use as a portable?
445301
Follow Up By: ross - Wednesday, Aug 09, 2006 at 14:45
I couldnt really see the benefits of mounting it permanently and I dont like making holes in my landcruiser's floor.
I also like my engine bay free of clutter so it stays in the shed until the weekends in its nice bag;)
445374
Follow Up By: Rock Crawler - Wednesday, Aug 09, 2006 at 17:29
dam , I should advertise there here again . I sell them for $280
445416
Reply By: Voxson (Adelaide) - Wednesday, Aug 09, 2006 at 10:32
The Max-Air has all my tyres pumped from 12psi to 38psi in the time it takes my mates with their arb's and alike to pump up 2 tyres....
188088
Reply By: Member - Ivan (ACT) - Wednesday, Aug 09, 2006 at 12:55
ditto - but it was the five year warranty that sealed the deal - I did have a cheapy (HD cheapy mind you ;-), but after 12 months it would only pump to 18psi
188123
Reply By: Member - Roachie (SA) - Wednesday, Aug 09, 2006 at 14:58
I've had a "real" Maxair for almost 4 years now. Permanently mounted, wired and plumbed up to 2 tanks. Until I recently bought my Feroza, I used to drive the Patrol every day and used the maxair daily to top-up the pressure for using air horns when needed (rarely), as
well as diff lock (rarely too).
A couple of months ago I bought a cheaper ($165-) copy of the maxair and I've mounted it beside the real maxair in the cargo area and coupled the 2 together. It has been going just as good as the Maxair,.....so far so good.
188150
Follow Up By: Muzzgit (WA) - Thursday, Aug 10, 2006 at 01:21
Roachie, I bet if you hooked them up to seperate tyres they would not be the same.
I have a Maxair copy and a good mate has the real thing. He can pump up 4 tyres, pack up, get out a folding chair and drink a beer while I've still got two tyres to go. we usually run the same tyre pressures.
445519
Reply By: GoneTroppo Member (FNQ) - Thursday, Aug 10, 2006 at 07:43
This difference between the real and the copy has come up a bit.
Does anyone know what the actual difference is?
The story you get, is they come out of the same factory blah blah blah.
188288
Reply By: Member - Omaroo (NSW) - Thursday, Aug 10, 2006 at 08:31
MaxAir - the best unit I've used, by far. Totally reliable after three years of flogging:
188294
