Cleaning Bird Stuff off canvas
Submitted: Wednesday, Aug 09, 2006 at 14:17
ThreadID: 36626 Views:2506 Replies:7 FollowUps:9
I've tried a search, but nothing quite fitted. Does anyone know how to clean off bird stuff from a canvas awning? We had a very birdy site in Broken Hill, leaving the awning very stained. I've tried only warm water so far, but the white stuff still remains. After a search here, many say not to use soap or detergents, as they will affect the waterproofing, but water alone isn't really shifting it. Thanks in anticipation.
Helena
Reply By: Garbutt - Wednesday, Aug 09, 2006 at 14:28
I've just cleaned our camper trailer tent with a soft bruch and running water and plenty elbow grease. I didn't use any cleaning stuff to hopefully protect the waterproofing.
GB
AnswerID: 188139
Follow Up By: Member - Julie P (VIC) - Thursday, Aug 10, 2006 at 20:05
Try microfibre cloths - i.e. Enjo - the green one is pretty good at getting just about anything off with no detergent at all - not an ad for Enjo - you can buy similar stuff in supermarket - I just happen to have Enjo and love it.
jules
FollowupID: 445662
Reply By: derraux - Wednesday, Aug 09, 2006 at 14:34
Yes
People are correct soaps do often upset waterproofing however the acid in the bird *#$% will in the long run do more damage my suggestion is use a MILD detergent water mix and a soft brush like one from a dustpan then check how it has affected your waterproofing and rewaterproof. If your mix is mild it should not affect it too much however where the bird stuff has been it may have been affected.
Derraux
AnswerID: 188141
Reply By: Big Kidz (Andrew & Jen) - Wednesday, Aug 09, 2006 at 14:35
I found that if you blow really gently that the feathers just sort of float away..
AnswerID: 188142
Follow Up By: D-Jack - Wednesday, Aug 09, 2006 at 18:56
Heee Heee Heee Heee HOOOOO!
FollowupID: 445432
Reply By: Member - Norm C (QLD) - Wednesday, Aug 09, 2006 at 14:47
I've just cleaned ours after the trip. Got the bird cr@p off OK using water spray and gentle rubbing with a cloth, but the tree sap and ground in red dust in a couple of areas is a different story. I think I'll be accepting it as part of the character of the CT.
AnswerID: 188146
Follow Up By: Des Lexic - Wednesday, Aug 09, 2006 at 15:41
As Norm suggested and you could use a mild detergent. Rewaterproofing the canvas is no big deal as you can buy waterproofing material, apply with brush or roller and let dry. From memory it was only $20 or $30 for a bottle.
FollowupID: 445386
Reply By: the outlaws - Wednesday, Aug 09, 2006 at 16:54
i used vinegar on my boat canvas and it worked a treat
AnswerID: 188168
Reply By: Member - Blue (VIC) - Wednesday, Aug 09, 2006 at 19:06
If I may slightly hijack this thread, can anyone recomend anything to get cat urine off canvas...??? Had the spare bedroom hanging in the garage after washing it thoroughly and the bloody cat from across the road decided to take a leak on it...
AnswerID: 188193
Follow Up By: Doggy Tease - Wednesday, Aug 09, 2006 at 19:14
Geez Blue, thats a bummer, try a small amout of Maguuires car wash in warm water, then rinse. You may have to repeat a few times. This is how i got rid of the same problem.
meow.
rick.
FollowupID: 445438
Follow Up By: Member - jeff M (SA) - Wednesday, Aug 09, 2006 at 19:40
After you wash it .Get a cat trap.That way problem solved.
FollowupID: 445449
Follow Up By: Member - Blue (VIC) - Wednesday, Aug 09, 2006 at 19:50
Thanks Rick...
Jeff,
Trouble is, the missus has a cat... Never had a problem with cat urine until the saimese moved in across the road.
FollowupID: 445452
Follow Up By: Spike me - Wednesday, Aug 09, 2006 at 19:53
How do you get people urine off the car roof? The guys in the upstairs flat pi$$ off their balcony on Saturday nights and it splashes onto our cars.
FollowupID: 445453
Follow Up By: Des Lexic - Wednesday, Aug 09, 2006 at 20:10
Spike me, Connect the car up to 240volts. Guarantee to stop them from doing it again.
FollowupID: 445464
Follow Up By: oldmagpie2 - Thursday, Aug 10, 2006 at 19:11
spike me, find out which car they own & leave a brown message on the drivers seat. with a note' piss on me , ill bleep e on you".cheers
FollowupID: 445654
Reply By: the outlaws - Thursday, Aug 10, 2006 at 09:32
I reckomend the use of lead for all cat problems :-)
AnswerID: 188304
