Swapping a 1HZ for a EFI or EDI 1HD-FTE
Submitted: Thursday, Aug 10, 2006 at 09:28
ThreadID: 36653 Views:20219 Replies:11 FollowUps:6
Hello crew, has anyone come across or would you know off hand,
if you can remove a 1HZ diesel motor from a GXL 100 series
and replace it with either the EFI or the EDI 1HD-FTE Turbo diesel motor??
More detail the better!
Regards Jason
Reply By: Member No 1- Thursday, Aug 10, 2006 at 09:48
lot lot cheaper to just get an aftermarket turbo fitted.
would'nt be lot, meaning difference in power etc, in it would there?
AnswerID: 188306
Follow Up By: Brooka27 - Thursday, Aug 10, 2006 at 09:57
Thanks for the reply.
Yes it will be cheaper in the short term, But wouldnt it be a better option to have a factory engine built for a turbo in place. More power and more reliable.
In the long term maybe cheaper??
Im chasing after what ever info I can get, so i can weigh up my options.
Cheers for the advice.
FollowupID: 445561
Reply By: Member - Captain (WA) - Thursday, Aug 10, 2006 at 11:38
Hi Jason,
On the 100 series manual 1HZ, the gearbox is the "Prado" 5 speed (R151 I think), unlike the H151(?) on the 1HD-FTE 100 series.
Upshot of this is that the factory turbos have a much stronger box than the 1HZ diesels. So even if you manage to overcome all the electronic issues with the wiring harnass of a 1HD-FTE it still leaves you with a "weak" gearbox compared to the factory turbo.
The cynic in me reckons Toyota did this to make aftermarket turboing of the 100 series 1HZ less atractive, all 80 series diesels had the heavy duty 5 speed gearbox regardles if turbo or not.
Captain
AnswerID: 188321
Follow Up By: Member - Davoe (Nullagine) - Sunday, Aug 13, 2006 at 18:18
The gearbox in a turbo 80 series is differnt to the normal 1hz gearbox. unsure if there is a strength differnce but they are different with different designations
FollowupID: 446069
Reply By: Turbo Diesel - Thursday, Aug 10, 2006 at 12:55
Jason
Thought about this myself, the 79 series ute has the live axel and turbo motor, so it should work in theory. But you would need the bigger gear box. If you eventually get an answer and can do the swap, well what a 4wd, comfort power and reliabilitiy. Talk to a conversion company for example IFS to Live Axel etc, they maybee able to help. for example it may be easier to remove the IFS than to swap the motor. Don't know for sure but worth a try.
AnswerID: 188334
Follow Up By: Brooka27 - Thursday, Aug 10, 2006 at 18:47
Hey Turbo, Its good to hear someone else who has actually thought about the idea!
Im only new to the 100 series range, would you know any places off hand that would do the IFS conversion?
Thanks JB
FollowupID: 445647
Follow Up By: Billowaggi - Thursday, Aug 10, 2006 at 22:48
The 79 series with the factory turbo engine [1HD-FTE ] have the heavy gearbox same as 100 series TD and all 80 series,
Regards Ken.
FollowupID: 445700
Reply By: Member - Stephen M (NSW) - Thursday, Aug 10, 2006 at 13:03
Id reckon go with after market turbo on what you got like "member no1" said at least you know how yours has been treated, if gear box gives you any trouble in the long run then worry about it, mate has turbo'd his had 40k on it when he bought it now has just over 100k (his is only the base model barn doors on the back) and no trouble so far,Doesnt tow a camper or any thing so maybe that might be an issue if towing gearbox wise. I think it would be a big job with all the wiring harness's sensors, etc. Just my opinion only. Regards Steve M
AnswerID: 188336
Reply By: traveller2 - Thursday, Aug 10, 2006 at 15:22
I think the 7x series always have the heavier box for each variant.
There are a few that I know of that have done it with the earlier turbo's.
If going the later electronic route you would be best to get a whole donor vehicle to ensure all the necessary wiring and black boxes are obtained as well.
AnswerID: 188352
Reply By: 100 Series - Thursday, Aug 10, 2006 at 15:35
I spoke with one of the 4wd wreckers in Brisbane about it a while ago, 10k for the engine, 4k to fit with a 5 speed auto included.
AnswerID: 188355
Reply By: Brooka27 - Thursday, Aug 10, 2006 at 18:42
Thanks too all who responded, I would like any other details in regards to wreckers names, numbers and stuff like that, as I am based in W.A's north.
Regards Jason Brooks.
AnswerID: 188403
Reply By: Spike me - Thursday, Aug 10, 2006 at 18:49
It would be far far far far cheaper to sell your vehicle and buy the factory turbo. You will also keep the skin on your knuckles.
Of course it is a different story if your motor is fu*$ed and you need to replace it anyway.
AnswerID: 188404
Follow Up By: Brooka27 - Thursday, Aug 10, 2006 at 18:53
G'Day, have you had experience in this area?
Have you got any info on IFS to live conversions?
FollowupID: 445648
Reply By: STEVE069 - Friday, Aug 11, 2006 at 09:51
Hi Jason, Give Matt a ring at Perth 4WD Centre. 87 Kew Street Welshpool.
ph 94701755 or web www.perth4wd.com.au
he imports half cuts of 4wd, give him a call and order a half cut that way you get everything you need.
Hope this helps.
Steve
AnswerID: 188482
Follow Up By: Brooka27 - Friday, Aug 11, 2006 at 21:47
Thanks Steve, will do that.
FollowupID: 445854
Reply By: Geoff (Newcastle, NSW) - Friday, Aug 11, 2006 at 22:24
Hello Jason,
My mate owns a 1HZ engined Troopy and I own a 1HD-FTE engined Troopy.
We parked them side by side one day and compared what would be involved in putting the 1HD-FTE into his Troopy.
Short answer, sheite loads!
Long answer, the whole wiring harness is just totally different. Fuel system is different in and around the engine bay.
There are a heap of electronic modules in the 1HD-FTE that just plain don't exist on the 1HZ. Even to the point where the 1HZ has a cable throttle and the 1HD-FTE is fly by wire.
By all means look into it, just be aware the differences are far more than the engine and gearbox.
Geoff.
Geoff,
AnswerID: 188607
Reply By: Member - Phil G (SA) - Sunday, Aug 13, 2006 at 17:32
Your easier option may be to slip a 1HD-FT (mechanical injection) rather than 1HD-FTE. And if you were to start with an auto GXL 100series, it may overcome the weak gearbox and clutch issue.
This gets discussed a fair bit on the LCOOL groups.
And converting an IFS to rigid may be difficult because of the different chassis widths.
AnswerID: 188796
