Nissan Patrol's Tires
Submitted: Wednesday, Mar 05, 2003 at 05:47
molopaa
Hi!
I have a 2002 GU Patrol and I'm going to be replacing the original tires/tyres soon. My question is that does anybody know what is the largest tire size I can fit on a stock Patrol. No lift kits or anything like that installed. 100% stock.
Also I plan on keeping the standard 16 inch rims.
Thanks in advance!
Reply By: Tony - Wednesday, Mar 05, 2003 at 08:32
265-75-16 seem to be about the best size for a std GU they "look" a bit bigger with a slight increase in height without going overboard.
14470
Follow Up By: Member - Melissa - Wednesday, Mar 05, 2003 at 15:59
We've got 265/75/16's on our GU and are very happy with this tyre size. Look good, feel good and fixed the approx 10km/h fast reading the speedo used to give with the standard tyres.
:o) Melissa
8741
Follow Up By: Jed - Saturday, Mar 08, 2003 at 16:11
Melissa (& others)
Can you advise if "fixed the approx 10km/h fast reading the speedo used to give with the standard tyres" is a known problem for std GU tyres (Bridgestone Dueler 265/70 AT 693)
I have a late 2001/2002 GU Patrol & have not heard about this problem before.
Jed
8875
Follow Up By: Member - Melissa - Monday, Mar 10, 2003 at 12:15
Hi Jed,
AFAIK, this is a known problem with GU's and the standard tyres. There have been several references made to the problem on this
forum in the past and in fact, is what prompted us to have our speedo checked, and sure enough....
Our GU is 1998 though so I can't really comment on whether the problem has been fixed in the later models. Perhaps a Nissan service centre could advise you.
An easy way to check is using the speed function in most good GPS units.
:o) Melissa
8925
Reply By: jason - Wednesday, Mar 05, 2003 at 11:57
265/75/16 seem to be the popular choice for patrol owners.i don't know how big you are looking to go but you must keep in mind the transport department rules on increaseing tyre diameter. in qld the limit is 25mm.that means if you increase the tyre diameter by more than 25mm your vehicle will be consdered illegal(insurance company can wipe your policy)also keep in mind that tyre diameters vary between brands even if they are the same size,so just because one brand is in the 25mm limit,another may not.i also have opinions on tyre brands if you want them.hope this helps
jason
14485
Follow Up By: Member - Kevin - Wednesday, Mar 05, 2003 at 12:15
Jason, NSW and ACT have similar requirement but limit is 15 mm. However, Nissan have a replacement tyre placard available from spare parts which caters for the 265/75 size, costs $17.40 from my local dealer in
Canberra. They have been available since 1998 I'm told by Nissan Technical as Nissan recognised the limited options available in 265/70 replacement tyres. Also, the cab-chassis comes standard with 265/75 tyres so there is no technical reason not to increase wagon tyre size to that. Nissan part number is 99090VB000A and it keeps RTA and, most importantly, your insurer happy. Picking
mine up today. I'll get about 35,000 KM from standard Bridgestone Dueller AT 693 and can't wait to replace them.
Kevin
8715
Follow Up By: Peter - Wednesday, Mar 05, 2003 at 13:47
Doing
well Kevin, you know what mileage you get out of your tyres even before you drive on them. Got 60000 out of
mine with regular balance and rotation. If you regard them so poorly why not get the dealer to put some GOOD tyres on.
just a thought Regards Peter
8727
Follow Up By: Will - Wednesday, Mar 05, 2003 at 14:10
Peter,
I have so far 98000kms on my BFGs all terrains 265/75 16... and they haven't had such an easy life, often used on rocky and chopped up country, (
Cape York and
Vic High country) being some of the
places they have been to....
They are still in the car and they are not yet on the tread wear indicator mark....
They have been rotated every 10000kms and balanced once.
Not a single puncture.
I guess that is what Kevin is looking forward to....
Just a thought regards Will
8729
Follow Up By: Member - Kevin - Wednesday, Mar 05, 2003 at 16:53
Peter - I'm good, but not that good. The tyres have now done 29,500 and judging by the wear, and comments from Bridgestone's technical people about how they not necessarily the best tyre for a Patrol, I think I'll be lucky to get 35,000 out of them. Tyres have been regularly rotated and balanced and most use has been on the blacktop commuting. Bridgestone recommend that I go to 265/75 604V Dueller with 13 mm tread Vs the 9mm on the OE tyre - they also suggested 35,000 - 40,000 would be pretty good out of the OE tyres.
8744
Reply By: Truckster - Wednesday, Mar 05, 2003 at 12:39
search the archives its been done....
Mate has 36 swampers on his 3.0 patrol, but 2in lift, so you should fit 33/34inch JT2's if you like.
14487
Reply By: molopaa - Wednesday, Mar 05, 2003 at 19:51
Thanks for the tidal wave of answers!
As I actually live in Finland, I can go up more than 25mm and still be totally legal.
I was thinkin something on the line of 285-300/70-75R
Will that fit?
And I'm also looking for a bullbar, but the best ones seem to sold in down under. You lucky bastards! =) Does anybody know if I can order a bullbar etc. from Australia? Would any company be willing to ship it to Finland?
14519
Follow Up By: rob - Wednesday, Mar 05, 2003 at 20:26
We have 285/75x16 duelers on our 2000 3L patrol size is ok tyres will be worn out about 50 000Kms.
8760
Follow Up By: Truckster - Thursday, Mar 06, 2003 at 00:08
Ahhhhh
Finland, then look here
Artic trucks!
8772
Follow Up By: molopaa - Thursday, Mar 06, 2003 at 03:06
I wish I could make my truck like that!
But I still use it primarily on the road and I would have to consult the local authorities about those wheels/lift kits.
According to the law, I can go up 51mm in diameter and 102mm in width from OE tires.
Thanks for all the answers. I guess I'll have to go shopping in a couple of weeks.
8775
Follow Up By: bruce.h - Thursday, Mar 06, 2003 at 19:44
gday guys
i have a video with 4x4s in iceland of similar kit to those on trucksters link shows them rolling one off the rim on ice they stop get fill the tyre with butain & light tyre pops straight back onto the rim got to be seen to bebelieved
8799
Follow Up By: molopaa - Thursday, Mar 06, 2003 at 20:40
I've seen it myself. It was on the Discovery channel once. It really was spectacular.
8802
Follow Up By: Truckster - Thursday, Mar 06, 2003 at 21:39
yup... its been done, but as Runsi (the bloke who has the Artic truck site)says many have died from doing this way...
8809
