Diff Breathers - GU Patrol
Submitted: Wednesday, Mar 05, 2003 at 14:39
rlbye
OK..before twenty people jump over me , yes I have looked at all in the Archive but!!!
*yes will extend the rear diff breather up into rear body panel
*BUT , do I really need to extend the front diff and gearbox breathers..they seem to be nicely tucked away up pretty high in engine bay.
And has anyone got ideas for securing long shovel and high lift jack to roof rack basket.
Reply By: Truckster - Wednesday, Mar 05, 2003 at 15:16
If you think they are happy with how high they are, then dont! Maybe one way filters off the top.
You can get a Spring Loaded Shovel Holders, you slide the head into the fitter, and then push the spring in, then the handle slides in. springs back locks it in.. Some place in Ferntree Gully sells them, I can find out of your more interested...
14499
Follow Up By: David - Wednesday, Mar 05, 2003 at 16:21
The Best diff etc breather setup I saw was on a friends Patrol
He plumbed them all to an airhorn compressor and when expecting deep
water he turned on the compressor- mounted in the car- thus positive pressue and no chance of
water ingress- beeutiful!!
8742
Follow Up By: rlbye - Wednesday, Mar 05, 2003 at 23:29
Thanks Truckster...shall keep my eye out for one way valves to fit and will see if anything is at next show to hold shovel and highlift...
Now thanks also David but sounds like positive pressure could lead to other troubles like popping seals
8771
Reply By: David - Thursday, Mar 06, 2003 at 18:52
I don't think you could ever pop a seal as the volume of air it would pump would be VERY low, buckleys chance of overpressurising anything....IMHO
14582
Reply By: Member - Bob L - Thursday, Mar 06, 2003 at 22:06
Ribye
Just so you dont waste your time suggest you keep an eye on the breather pipes where they are joined at the base of the firewall. Have found the rubber pipes to become dislodged in timber country ie when picking up unwanted passengers(sticks).
When crossing deep
water I always take the opportunity to check the plumbing while waiting for the transmission/diff to cool down before entering the
water.
14593
Follow Up By: diamond - Saturday, Mar 08, 2003 at 17:06
smart man
8877
