Patrol zd30 Clutch replacement options?
Submitted: Wednesday, Aug 16, 2006 at 22:12
Grandpa joe
My patrols clutch is due for a freshen up and I am trying to decide wether to replace with A: O.E.M. B: Safari Heavy Duty kit to suit the original flywheel, or C: Safari Heavy Duty kit with flywheel (Traditional flywheel conversion kit). Any ones input that has tried these kits I would appreciate their input,
Clear as mud, Joe
Reply By: srowlandson - Wednesday, Aug 16, 2006 at 22:40
I replaced the clutch in my ZD30 and had the flywheel machined, about 1 year later the fly wheel cracked and needed replacing, luckily it was warrannty, otherwise $2500.
clutch was $1500.
i'd go the standard clutch conversion and get rid of the ripoff dual mesh one.
Steve
189394
Follow Up By: Grandpa joe - Wednesday, Aug 16, 2006 at 22:51
Thankyou Steve, you read my mind! .......How many km did you do before the original flywheel croaked in front of the replacement clutch and was the pressure plate a standard one?
446906
Reply By: blown_zd30 - Thursday, Aug 17, 2006 at 10:40
G'day Joe
I first replaced the clutch in my ZD30 '01 model at 120,000klms with the Daikin Safari HD unit, at that point the factory flywheel was deemed OK and went straight back in.
When they engine failed at 244,000 and taking advantage of the cost saving in labour we decided to replace the clutch again with the same Safari HD clutch kit......but............when the donk came out we discovered the flywheel this time was completely buggered with massive amounts of play between the two sections.
We replaced it with the genuine nissan dual mass flywheel at a cost of around $2500 plus I put the same safari HD clutch kit in again.
I didn't realise there were other flywheel options at that time.
Brad
189450
Reply By: DavidT - Thursday, Aug 17, 2006 at 13:39
By Replacing the Flywheel with a solid one could this cause any warranty issues down the line re gearbox etc plus would it be better on the clutch life.
Dave T
189484
Reply By: 120scruiser (NSW) - Thursday, Aug 17, 2006 at 19:54
I have replaced the dual mass flywheel with the Daiken solid state flywheel and clutch kit in my workshop. No problems from that day on. We have seen flywheels go as low as 60 000 km. At this stage Nissan usually rectify under warranty. Once we have fitted the solid flywheel we have found a much better pedal feel and you don't appear to get that dragging feeling when taking off.
You can check our site at
Patrol Info
May be of some help.
120scruiser
BTW we have an EGR blanking kit that we are fitting to the ZD30 engines as
189552
Follow Up By: Grandpa joe - Wednesday, Aug 23, 2006 at 22:00
Will E-mail you about this
448267
