Jeep Cherokee Sports
Submitted: Thursday, Aug 17, 2006 at 17:31
Pet
My Jeep has recently just stopped for no reason middle of the road , the engine just stops and I have to try to get on the verge as the power steering is disabled , has anyone else had this problem ?
Reply By: Member - Omaroo (NSW) - Thursday, Aug 17, 2006 at 17:54
How long is a bit of string?...... it'd be easier if we were given some details!
What year/model - XJ or KJ? Diesel or petrol?
Did you get a bad drop of
fuel?
189537
Follow Up By: Pet - Friday, Aug 18, 2006 at 08:56
The Jeep is a 94 petrol and the
tank was full both times it cut out. I was travelling along a straight flat road when the engine just cut out , I had to then pull over as best I could as the steering locked up , waited 5 minutes and it started up ok. Then an hour later it did it again same road other direction.
Anyone else had this trouble ?
I have had the jeep 10 years , first time it has let me down.
Petra.
447086
Follow Up By: Member - Omaroo (NSW) - Friday, Aug 18, 2006 at 09:03
Hey there Petra :)
It really sounds like you may have picked up some bad
fuel that's clogged the filters. Is the
fuel station you wnt to reputable do you think? Might be worth asking them if they've had problems over the past few days. Honest ones will tell you the truth.
Other than that - how are all you fluid levels - and especially the radiator? You haven't overheated I wouldn't think because you would have had steam everywhere.
I'd ask the guys on AusJeepOffroad www.ausjeepoffroad.com/forum/index.php if I were you.... Go to the Cherokee section, and by the way - you have an "XJ".
Chris
447089
Follow Up By: Member - Omaroo (NSW) - Friday, Aug 18, 2006 at 11:39
Sorry - you mentioned "the
tank was full both times it cut out" so I assume that you'd just filled up prior to the stoppage, correct?
447113
Reply By: GaryInOz (Vic) - Thursday, Aug 17, 2006 at 23:03
It's a jeep thing, no-one understands.....
Seriously, need more information:
Carbie/EFI
other symptoms, stumbling, missing, hesitation, poor performance, check engine light, etc.
error codes from EFI
Stopped only once or often
adequate fuel/
fuel pressure/spark.
189584
Reply By: Member - RockyOne - Friday, Aug 18, 2006 at 08:13
Even the mighty Jeep™ needs
fuel..Start there..You sure did'nt divulge many details..Is this dinkum or just a jealous "Jeep Knocker" ? I have two and can't fault them..Diesel & gasoline.
189612
Reply By: Member - Alastair D (NSW) - Friday, Aug 18, 2006 at 09:55
Pet,
Never had a Jeep but had a similar problem with a car. The breather to the
fuel tank had blocked and the vacuum build up was such that the pump could not do the job.
Next time it happens take the
fuel cap off and see if you hear it sucking air in a big way. Then try to start.
The
fuel system plumbing is complex nowadays so it may be hard to work out where the problem is if I am right.
just a thought
alastair
189626
