Snorkel
Submitted: Thursday, Mar 06, 2003 at 11:31
Stefan
I have just lerarned from ARB that there is no Safari
snorkel for the 1996 Pajero GLS NK 3.5l V 6 Petrol. Are there any other brands that do SNorkels for this particular vehicle? I have heard that Airtech is not very good due to problems with air intake and also rough fitting. Anyone can help me with this? Thanks for any info!!!!
Stefan
Reply By: Member - Paul- Thursday, Mar 06, 2003 at 12:13
The Safari
snorkel that suits the NJ will also fit the NK. I fitted one myself last year. Just confirm that your aircleaner is in the same position. ie parralel with the RH fender behind the headlight.The aluminium flange supplied in the kit fits to the inside of the fender in the same way for both the NJ & NK. The air box nees to be sealed properly & the plastic flange from the aircleaner needs to be sealed against the RH side of the engine bay. silastic will do the job.
14559
Reply By: Savvas - Thursday, Mar 06, 2003 at 12:27
You can also try TJM for the Airtec
snorkel.
14560
Follow Up By: Member - Paul- Thursday, Mar 06, 2003 at 16:09
Airtec will tell you they don't have one to suit the NK.
8788
Reply By: Member - AndrewPatrol - Thursday, Mar 06, 2003 at 18:43
I fitted a Safari 3 litrre
snorkel to a 3.5 (single cam NL). Just make sure as above about the air box location. They might say they won't sell it to you but tell them that you want to line it up against the car and that others have done it. INSIST. see other threads below recently, something about hole saws.
14581
