compressor location 80 series
Submitted: Friday, Aug 25, 2006 at 18:11
ThreadID: 37112 Views:1877 Replies:5 FollowUps:4
hi all,just wondering where every one puts there arb compressor in a 80 series cruiser,under the seat at the moment but not enough room to put airline in soleniod for air lockers and i dont have much room left under bonnet.
thanks shad..
Reply By: Of Mice & Men - Friday, Aug 25, 2006 at 18:59
Hi Weaponhead,
Im working tomorrow, if you like, you can have a look at where I put mine.
Thanks for the trailer bearings.
Regards, OM&M.
AnswerID: 190992
Follow Up By: Member - shad D (NSW) - Friday, Aug 25, 2006 at 19:39
Hi OM&M,
i might come down and have a look, do you know what time you are finishing,thanks mate.
shad (weaponhead)..
dont ask why they call me weaponhead..!MPG:3!
FollowupID: 448717
Follow Up By: Of Mice & Men - Friday, Aug 25, 2006 at 21:06
Shad,
I'll be finishing at 10. Mines mounted in the rear now beside my drawer system. Not sure if you could do the same, but have a look anyway if you like.
OM&M.
FollowupID: 448741
Reply By: Middle Jeff - Friday, Aug 25, 2006 at 19:34
I have my one under the seat with both lockers connected, just move it around a bit and put elbows on the air lines.
Nice and easy.
Have fun
Craig
AnswerID: 190998
Follow Up By: Member - shad D (NSW) - Friday, Aug 25, 2006 at 19:43
thanks craig,
seems like a good spot i will have a fiddle with it tomorrow then,
thanks for that
shad...
FollowupID: 448719
Reply By: Hairy - Friday, Aug 25, 2006 at 22:08
Im in the process of making one to fit in the bull bar, havent done it yet but depending on your bar, there is quite often a bit of spare room in there.
AnswerID: 191053
Reply By: Alan H (Narangba QLD) - Saturday, Aug 26, 2006 at 16:07
I have a Big Red compresser under the bonnet.
It is bolted to a flat board (5ply) which is trapped under the second battery so that the compressor is is between the battery and the grill. The hose connector is at the top and I have not permanently wired it.
To use, lift bonnet, connect hose, put clamps on battery. It has lived and worked there for several years now.
Carrying the hose is the pain. It travells in the back somewhere beside the fridge as under the seat is occupied by an inverter.
AnswerID: 191134
Reply By: Member - Howard (ACT) - Sunday, Aug 27, 2006 at 17:19
Shad,
plenty of options for an 80 series
I got 3 air compressors.
1 under seat for air locker
1 under bonnet passenger side , behind battery,On metal shelf above wheel arch which is connected to air tank behind bullbar.
1 in the drawer unit (portable unit)
justs takes time to make up all the mountings to miss all the other bits and pieces
Howard
Resigned to Retirement
AnswerID: 191292
Follow Up By: Member - shad D (NSW) - Sunday, Aug 27, 2006 at 20:24
thanks for all the info guys,i have put it under my drivers seat for my air lockers.
i also have a spare compressor which i think i will put somewhere and a air tank
thanks shad..
FollowupID: 449070
