engine transplant
Submitted: Saturday, Aug 26, 2006 at 09:32
ThreadID: 37125 Views:2277 Replies:8 FollowUps:3
Hi guys! I'm contemplating in a engine transplant for my 80 series (on gas) ... I'm living in Adelaide ... do you have any suggestion??? Maybe a 5.0 lt V8 commodore??
Thanks!
Luca
Reply By: old mate - Saturday, Aug 26, 2006 at 11:19
Why the change?
AnswerID: 191110
Reply By: Member - Dedalus (SA) - Saturday, Aug 26, 2006 at 12:01
... large crack in the block engine ..... water in oil ..... kaput!
Luca
AnswerID: 191113
Reply By: old mate - Saturday, Aug 26, 2006 at 12:47
I've seen 5.0 litres V8's (carby type ex VH commodore) in 75 series cruisers so your 80 should be do able. An EFI 5.0 litre?, who knows, I assume it would fit. Have you looked at a second hand 80 series engine and maybe throw in some new rings and bearings and compared this to the transplant, modifications, hooking it up to gas and legalities?
Best of luck.
BTW, how many k's had your last engine done?
AnswerID: 191119
Follow Up By: adamj1300 - Saturday, Aug 26, 2006 at 12:54
try in the www.outerlimits4x4.com forums a few of the guys have done them to there GQ patrols put the 5.0 efi v8 in them
FollowupID: 448840
Reply By: Alan H (Narangba QLD) - Saturday, Aug 26, 2006 at 15:41
What about a V8 chevy??
See this link for replacement engines.
www.linquip.com.au/specs.htm
AnswerID: 191131
Follow Up By: adamj1300 - Saturday, Aug 26, 2006 at 16:49
i looked in to one of them for my GU and was quoted any where from $15,000, up to $21000 ish with out turbo, from linquip & brunswick over in perth! & thats for a 2.8 gu & including having the clutch & gearbox swapped as well, there not as srong as the 4.2s and with the diesel prices going the way they are i couldn't justify going for one also i don't do enough heavy towing
as Dedalus (SA) said that he already has gas hooked up so the 5.0 (308) efi or even carby would be perfect swap provided where u live & the need for a long range between drinks?
FollowupID: 448865
Reply By: Exploder - Saturday, Aug 26, 2006 at 20:07
Yeah bung a V8 in it, hell you would probably get better fuel consumption than what the 4.5 gave ya.
My mate has a statesman with the 5 litre in it, on a run from Kalgoorlie to Perth (600K’s) cruising at 120Kp/h it returned around 10 litres per 100, pulled into his driveway just as the fuel light came on.
AnswerID: 191174
Reply By: bigcol - Sunday, Aug 27, 2006 at 02:50
If your going to put a V8 in it , don't muck around with the 5.0L Holden.
Stick a 5.7l Gen 3 in it. Just make sure it's out of a VY or VZ. That way you shouldn't get one of those rattly oil burning POS.
The Gen3 makes way more horsepower is lighter, smoother ,queiter and doesn't sound like some guy slapping a couple of thongs together..
Saw a GQ ute with one in it at the Cape when we were up there not long ago.
Cheers Col
AnswerID: 191216
Follow Up By: bigcol - Sunday, Aug 27, 2006 at 02:52
Forgot the important thing.
It'll also use less fuel than the 5.0L
FollowupID: 448932
Reply By: Member - Dedalus (SA) - Sunday, Aug 27, 2006 at 10:11
Thanks to all for the reply. At the moment I'm nos sure about what to do but I will very happy with a V8 on my enginebox
Luca
AnswerID: 191235
Reply By: Member - Pesty (SA) - Sunday, Aug 27, 2006 at 23:30
Hi Luca,
Yes 5 litre efi would be good transplant, at wreckers for about $2000 these days, plus marks adaptor kit and a few changes. Have a mate with 4.2 deisel doing the maths at the moment and going that way on gas in his trol.
He was saying go with a after market type computer setup, rather than the original holden one, will find out more for you if you get that fa.
Will see you in 6 weeks too mate when our 4wd club will be coming to the island for 9 days
Cheers Pesty
AnswerID: 191367
