Tuesday, Aug 29, 2006 at 09:59
G'day Craig,
The set-up you describe is virtually identical to that used as standard in the GU....and as far as I'm concerned it works really
well. The only difference is that you have only one gauge ; switchable between the 2 tanks.....which sounds quite okay to me.
However, I understand that Toyota Landcruisers (for example) use a system whereby there is a dashboard switch which physically isolates one
tank or the other. That system also works quite
well apparently.
I'm not sure I'd bother changing the current system if it's actually working okay. It is nice and simple with no solenoids (I think that is what Toyotas use to switch over) to go kaput. The worst thing that can go wrong with your set-up is that the pump could stuff up.
By the way, on the GU, the transfer pump pumps the
fuel back up to the top of
the neck of the filler for the main
tank.....open the filler cap when you've got the transfer pump switched on and you can see the diesel coming out of the pipe. Not sure where your's pumps into......if it's the
tank itself there could be an issue with air lock or something (but I wouldn't have thought so).
Hope this helps......my advise; if it ain't broke, don't fix it......
Cheers mate
Roachie
449416
