New Cast Iron Plate
Submitted: Thursday, Aug 31, 2006 at 15:02
Ron173
I recently bought one of those cast iron plates for cooking on, its made by companion, but best is, it not only works with a fire, its made to fit 2/3 burner stoves, it just sits on top your stove... instant barbie! Dran good fit too
I have a 3 burner and it runs this cast iron plate with just middle burner on so low, and whole plate end to end is stinking hot, great for cooking on and after I lift it off onto ground and throw
water on it and it self cleans.
(I always wonder why cast iron doesnt crack when you do that.... I figure that the
water boils straight away, itd prob crack if you threw it in a pool or similair)
All for $28
Top buy if you ask me
Ron
Reply By: Hayjude - Thursday, Aug 31, 2006 at 15:10
Yep you're right, they are a top buy. We bought one at the beginning of the year from Big W. We only paid $20 though.
191993
Reply By: Mr Fawlty - Thursday, Aug 31, 2006 at 15:25
I bought a single burner stove with the plate in a hard plastic case @ the Warehouse for $19.95 & 6 EXTRA GAS CARTRIDGES FOR $5.95...
So Ner Ner Ner.... best piece of kit I've ever owned....
191995
Reply By: Hairy - Thursday, Aug 31, 2006 at 16:08
Careful mate, it will crack if its hot enough and you throw too much
water on it!
191999
Reply By: Member No 1- Thursday, Aug 31, 2006 at 17:27
i'm with Hairy...he is right..
it will crack..eventually..i have 1st hand experince on that :(
192004
Reply By: HGMonaro - Thursday, Aug 31, 2006 at 19:40
what's the dimensions? Looking for something like that.
192039
Reply By: Grizzle - Friday, Sep 01, 2006 at 10:34
Cast Iron cracks because it has a high rate of expansion and contraction when heated. It normally cracks whe you cool down only a portion of it.
I burn off my
camp ovens and then drop them in
water all the time. As long as you immerse the whole thing at the same time you should be ok.
192125
Reply By: Member - AVA 191 (QLD) - Friday, Sep 01, 2006 at 15:12
Yes Ron - we bought one at
Easter to stick on our 2 burner and it was
well worthwhile. We also use it directly over a wood fire (when campsites allow open fires).
The little butane gas stove mentioned above are also very handy - we regularly use both to speed up cooking.
192196
Reply By: Ron173 - Sunday, Sep 03, 2006 at 19:10
Dimensions... would be 17.5 inches by 8.5 inches.
Tried one of those gas types with the cartridges and had the ring thing which you put
water in to catch fat etc. but we never really rated it, it used to have meat stick to it and was impossible to clean right, dont think it was real cast iron though.
As for cleaning with cold
water, I've always done this with barbies,
camp ovens etc, never had one crack yet, just cleans em up real good real fast n easy.
If you dont use this method, how do you clean yours then?
Ron
192527
