Camper Trailer Kitchen
Submitted: Thursday, Aug 31, 2006 at 16:50
ThreadID: 37287 Views:8601 Replies:8 FollowUps:8
I'm putting together a trailer & would appreciate input from those who have made their own kitchen set up. I intend to use ply sheeting & will be a slide in type, not
swung on the tailgate. Trailer has other functions. Plan so far is 120cm long,30 wide & 45 high. Hinged top on top of top (??) to act as backboard. One compartment to suit stove and perhaps two/three others. Thought I'd use appropriate
sizes plastic boxes to hold stuff, with good fastening lids. Front panel of ply box to
hinge downward as access & provide exta bench space. Thats about the plan, so will appreciate any tips.
Regards..Baz.
Reply By: Vince NSW - Thursday, Aug 31, 2006 at 17:04
My Kitchen is made in alloy and counter levered on body. Tried to attache pics but it did not work. Let me have an email address & I will send
Vince
AnswerID: 192002
Follow Up By: oldbaz - Thursday, Aug 31, 2006 at 18:01
Thanks Vince, try bmedway@austarnet.com.au
Regards..Baz
FollowupID: 449881
Follow Up By: oldbaz - Friday, Sep 01, 2006 at 11:45
Vince, pics received ,thank you, havent had time to inspect yet.
Appreciate your effort. Regards Baz.
FollowupID: 449995
Reply By: DavidT - Thursday, Aug 31, 2006 at 17:28
We contracted the building of our trailer out to a couple of companies and we put a DRIFTA Kitchen on and it is the best money spent we have cooked for large groups and it has stood up well, it is a tailgate job
Dave T
AnswerID: 192005
Reply By: Barnesy - Thursday, Aug 31, 2006 at 18:01
Baz,
I have just finished making my own kitchen, slide out no swing out. I used 12mm mdf board as i think it's better than ply for screwing into the egdes, ply tends to split. I looked at Drifta kitchens but for $1000 i couldn't justify it.
I bought plastic containers, two large ones for storage and 3 smaller ones for everyday items. I am able to fit one small drawer for cutlery. I will leave one space for fry pan, saucepans etc. Also bought a cast iron gas cooker and measured it all up. Took the boards to my local cabinet maker who cut it up for a minimal charge. Simply screwed the wood together.
I have a recessed cooker area that i have lined with stainless steel. Also have SS windbreaks that are removable. The top of the kitchen is laminated chip board, the recessed area still has a laminated top to cover the cooker during transport that is removable and can be connected to the end to make more table space. I will hook the tap to the end of the kitchen box and cut a hole in the removable top for the sink to fit in.
I got some angle iron that i'll bolt to the trailer floor to act as guides, and some 10mm nylon that i cut up to make sliders. I made it fit the whole length and height and just under half the width of the trailer: dimensions, 1700 X 450 wide X 460 high.
The SS was a splurge but apart from that the whole thing including cooker, plastic containers etc cost about $250. Could put it together in a weekend. Sounds better to me than $1000.
Have a look on the internet at different kitchens. Drifta site is good for ideas.
Barnesy
AnswerID: 192016
Follow Up By: DavidT - Thursday, Aug 31, 2006 at 18:24
It was not a $1000.00
FollowupID: 449888
Follow Up By: oldbaz - Thursday, Aug 31, 2006 at 18:26
Sorry Barnesy, I hit the wrong button. See below.. Baz
FollowupID: 449890
Reply By: mfewster - Thursday, Aug 31, 2006 at 18:17
I built one using Qbelock aluminium tubing as the frame and covered it with 5 ply attached by bolting through the ply and qblock.Keeps everything rigid without having to do joints in the woodwork. I used plastic drawer units. Much easier and lighter than making them from wood.
AnswerID: 192021
Follow Up By: oldbaz - Thursday, Aug 31, 2006 at 18:24
mfewster, now thats something else to consider, timber jointing has its problems.
Thanks for your interest.
Regards Baz.
FollowupID: 449889
Reply By: oldbaz - Thursday, Aug 31, 2006 at 18:20
Barnesy, you are a man after my own heart, what a wealth of good information
you have given. The SS around the cooker sounds good. Mine would be a slightly
smaller scale but similar in other respects. Will check the web as suggested.
Thanks for the effort, just what I was after, you're a little champion!!
Like you I cant justify $1000 either, would sooner spend the difference on a
good supply of Bundy to sup around the fire.
Regards.. Baz
AnswerID: 192023
Reply By: Dirty Smitty - Thursday, Aug 31, 2006 at 18:59
Baz,
I am currently in the process of building a camper trailer, is the standard dimensions 7x4 or 7x4"6 ? Sorry for being a bit off topic, I just saw your query and I thought that I would ask. Your help would be appreciated.
Regards,
Smitty.
AnswerID: 192029
Follow Up By: oldbaz - Friday, Sep 01, 2006 at 11:36
Smitty, the trailer I am using is a 7 by 4 with 50cm sides. I cant see why a 7 by
4'6" woulnt be ok. My camper top overhangs nearly to the width of the mudguards.
Check the height from ground will suit the camper top you are using. If I can be of
further help, my email appears above in another post.
Regards Baz.
FollowupID: 449988
Reply By: Member - Brian (Gold Coast) - Thursday, Aug 31, 2006 at 19:18
Our kitchen is one of those Coleman Camp Kitchens..... not attached to the trailer. Leaves a lot of room and the kitchen can be anywhere we choose it to be on our camp site!
Just another idea....
Brian
AnswerID: 192036
Follow Up By: oldbaz - Friday, Sep 01, 2006 at 11:39
Brian, your kitchen certainly offers that flexibility, but all must be stowed somewhere, & the slide in concept is winning at the moment. Appreciate your
input. Regards Baz.
FollowupID: 449991
Reply By: otrom - Thursday, Aug 31, 2006 at 21:22
I had a camper trailer (until it was stolen - another story) which had a slide out kitchen. We had a small gas bottle holder and 2KG gas bottle attached to the end of the slide out kitchen and connected to the stove permanently. We found this very handy, saved having to connect and disconnect the gas bottle all the time. Something to think about anyway.
Cheers.
AnswerID: 192053
Follow Up By: oldbaz - Friday, Sep 01, 2006 at 11:43
An interesting idea. Not sure about the legality of internally stored gas cylinders,
but the permanent connection has appeal. Thanks for the help.
regards Baz.
FollowupID: 449994
