Window cleaner
Submitted: Tuesday, Sep 05, 2006 at 09:57
Member - GeeTee (NT)
Hi all, I have a problem with the rear windows of my Prado. They are badly
water stained. I have tried the usual cleaners, steel wool, cutting compound etc. to no avail. Any sugestions ?
GeeTee
Reply By: Leroy - Tuesday, Sep 05, 2006 at 10:00
are you sure it's the windows stained and not the tinting on the windows?
Leroy
192895
Follow Up By: Member - GeeTee (NT) - Tuesday, Sep 05, 2006 at 10:16
Yep I'm sure Leroy. You can feel it on the outside surface of the glass.
GeeTee
450736
Reply By: MAVERICK(WA) - Tuesday, Sep 05, 2006 at 11:25
a long time ago the windows on my parents house were stained from the
bore - nothing we tried would shift the stains...........we ended up getting a pro window bloke who used a compound and buffer and all was clear. maybe try either a window place or a panel beaters as they will have plenty of non-scratching compounds you could try. rgds
192906
Reply By: Member No 1- Tuesday, Sep 05, 2006 at 11:49
CLR..or what ever its called...get it from hardware store. It is what you use to clean kettles etc etc of lime and calcium
192910
Reply By: Moose - Tuesday, Sep 05, 2006 at 13:12
G'day GeeTee
Just as a matter of interest how did they get stained? Have never heard of this before.
192922
Follow Up By: Member - GeeTee (NT) - Tuesday, Sep 05, 2006 at 13:27
Hi Moose, Partly caused by
overflow etc. from a
water tube I have mounted on the roof rack.
GeeTee
450771
Reply By: Pajman Pete (SA) - Tuesday, Sep 05, 2006 at 13:55
Here are some ideas:
Glass Cleaning
192928
Reply By: Andrew-rodeo - Tuesday, Sep 05, 2006 at 21:28
Toothpaste. And elbow grease. This is one of the best things u can use for polishing stuff like that.
193033
Reply By: George_M - Tuesday, Sep 05, 2006 at 21:41
GT
There has been a fair amount of discussion about this issue (early August I think)at autos.groups.yahoo.com/group/120scool/
People are using some interesting stuff to keep their windows clean. Elbow grease seems to figure prominently:-)
George_M
193041
Follow Up By: Member - Andrew W (SA) - Wednesday, Sep 06, 2006 at 00:13
I take it playdoes are more prone to it?
450881
Reply By: Member - John R (NSW) - Wednesday, Sep 06, 2006 at 06:15
GeeTee,
Don't use steel wool! Believe it or not, you might actually scratch the glass.
When I was in the glass industry, we used cerium oxide mixed into a paste and elbow grease to polish out imperfections.
If your glass has what I think it has, you won't be able to fix it. When the glasses are manufactured, sometimes they are put into the plastic bags for shipping while the glass is still warm (from the furnace). The glass has a reaction with something in the plastic (particularly if they're stacked without a gap between the glasses). That's what gives you the weird
water-stained look. It can be on both sides of the glass.
We used to see this sort of thing semi-regularly.
Unfortunately, there's not really much you can do except "recycle the glass". If the vehicle's under warranty I'd be pressing for a swap.
This isn't limited to any make of vehicle as it happens at the glass maker's.
193064
