LOKKA - any updates?
Submitted: Thursday, Sep 07, 2006 at 11:10
D-Jack
Hi all
Just before I go and order a LOKKA for my TD JAck, just wondering if there have been any new opinions or experiences with them, in any vehicle, since the last round of posts in relation to these diff locks. Any problems encountered, manufacturing faults, warranty claims, driving problems etc.
Will be using
mine mainly for beach/dune, occasional mud.
Experience from other late model Jackaroo owners especially appreciated.
D-Jack
Reply By: Rigor - Thursday, Sep 07, 2006 at 11:42
Can't help with your request Djack but curios , are you fitting front or rear?
Dave L
193277
Reply By: SA_Patrol - Thursday, Sep 07, 2006 at 16:59
Best bet is ask someone from the Holden 4wd club.
193314
Reply By: navaraman - Thursday, Sep 07, 2006 at 17:04
D Jack I'm about to fit a Lockright in the front of my Patrol, (very similar to a Lokka) a mate of
mine has one in the front of his Jackeroo and he has had no problems with his in his TD Jack and I'm happy to follow his example.
193316
Reply By: Rock Crawler - Thursday, Sep 07, 2006 at 17:06
ok , so i asume, you want a LOKKa from
Adelaide . they work
well , forget the fitting it yourself in the driveway crap they pedal.
It will have to go to a diff place , so they can space it according to the ware in your diff.
Mine worked
well , but I did shear the pins once , not covered under any warranty , not a expensive item , but a pain to pull the center out again.
My next one will be a TJM version.
I will be fitting a air locker in the front from ARB, there been around a long time . I know the TLM lockers are a JM product , but havent been around long enough to prove them selves to me yet.
The reason I want to run both , Mechanical and air locker ? to have a working locker if either fails . If my compressor fails , I wouldnt hav any lockers , so this way one or the other will work.
193318
Reply By: Member - Bruce and Anne - Thursday, Sep 07, 2006 at 20:17
Hi D-Jack, I have just put one in the front diff in my Isuzu MU which is the same Lokka as you will need and so far it is brilliant. I replaced my auto locking hubs at the same time, put manual ones in, and yes unless you have full work
shop it is a big job, first you have to pull the front end out of the vehicle.
Probably the most important thing when you have a Lokka fitted is not to give it the gas when driving it in extreme situations, could brake a cv, but with the Lokka you dont need to give it the gas just let it walk up and over, great no spinning
wheels less dust just great. My mechanic charged me $230 good value when it took 6.5 hours, his first one. Some times its good living in a little country town.
Cheers Bruce
193341
Reply By: Member - Doug T (W.A) - Thursday, Sep 07, 2006 at 20:47
If you want to buy something cheap that could let you down when the going gets tough go and get LOKKA but if you want something that is a bit more expensive and won't ley you down when the going gets tough go and buy yourself a Detroit No-Spin ,check links
www.locked-drive.com.au/product.htm
Site Link
www.difflap.com.au/
193353
Reply By: ACDC - Friday, Sep 08, 2006 at 19:09
Save your money and buy an air locker you can turn on and off.
Had lockrights in a 60 series years ago, once you engage 4wd they lock and stay locked, the wind up between front and rear diffs keep a load on the locker.
193571
Follow Up By: D-Jack - Tuesday, Sep 19, 2006 at 17:15
I will just turn
mine on and off with by disengaging 4wd inside the cabin.
453426
Follow Up By: Truckster (Vic) - Tuesday, Sep 19, 2006 at 17:34
Im with ACDC by a million
miles.
453427
