Small oil leak on a 3.0 ltr TD, help required please....
Submitted: Tuesday, Sep 12, 2006 at 10:29
Martyn (WA)
Forumites,
Bit specific this one, on the front of my 3.0 TD engine looking at the crankshaft pulley there is a threaded plug which is a blanking plug, just behind that and to the left is a small weep hole which every now and again releases a small drip of oil. What is this and what does it indicate, I spoke to the Nissan agent who advises me the plug is leaking and needs re sealing, despite me trying to convince him otherwise he didn't move on his opinion, can anyone help me here? I have a picture which is now number five picture in my profile pictures, the small screw driver blade points to where the oil drip comes from.
Any constructive help welcomed thanks to those who respond, a constructive solution would also be appreciated, this doesn't mean buy a Toyota.........
Reply By: hl - Tuesday, Sep 12, 2006 at 10:44
Why would you argue with them if they're trying to fix it?
On the other hand, it's only a drop now and then, why bother?
194111
Follow Up By: Martyn (WA) - Tuesday, Sep 12, 2006 at 11:13
hl,
I wasn't arguing with them, all I wanted was the guy to listen to me, to try and understand what I was asking for rather than assuming that the plug was the problem. He couldn't tell me what the hole was there for, he works for the Nissan service division, what chance have I got. I'm not that bothered, I was just trying to find out what the hole was there for and why there was a small amount of oil leaking out.
If officer Dibble stops you and inspects the vehicle and notices an oil leak he will sticker the vehicle until you fix it, that's the only reason. If I tell him not to be bothered about it I can imagine his response.
452010
Follow Up By: hl - Tuesday, Sep 12, 2006 at 12:44
Actually,
mine has a bit of a weep there too. At first I thought it was from spilling a bit when filling it up with oil, but it comes back after cleaning it. It does not seem to get any worse.
Mine has just under 70,000k on it.
As for officer Dibble... he would order me executed if I rolled up in my 10 year old Falcon...
452022
Follow Up By: Martyn (WA) - Tuesday, Sep 12, 2006 at 20:27
Hl,
Thanks for the response, I was hoping you didn't take my esponse the wrong way thankfully you didn't. I've had a further look tonight and cleaned the area up, looks to be coming from around the gasket area not the main seal. I'll give a general response to all suggestion later in the thread.
452094
Reply By: Snowy 3.0iTD - Tuesday, Sep 12, 2006 at 10:57
Martyn
Looking at the photo I am not sure what this hole is for, but most of the oil is in front of the hole, which means one of two things; either you drive really fast in reverse or that the oil is coming from somethwhere in front of the stain, the crankshaft seal maybe? The oil that sprays back may acumulate in this hole, so that when you stop out comes a small drip.
Snowy
194113
Follow Up By: RosscoH - Tuesday, Sep 12, 2006 at 11:06
I could swear you took the photo underneath
mine, looks just like
mine. Wouldn't worry too much, doesn't look too wet,
mine has looked like that for 2 years.
452008
Follow Up By: Martyn (WA) - Tuesday, Sep 12, 2006 at 11:07
Snowy,
I know what your saying about the driving backwards quickly, and where the oil is, the crankshaft oil seems to be fine when I shine the torch up behind the pulley, from the drips that came out after the long run I had at the weekend the oil seemed to drip directly from this hole, I was just wondering what it was there for. There doesn't appear to be any reference to this plug or drain hole in the manual. One thing I have changed is now I've moved to a full synthetic oil which does tend to be a tad more searching than normal mineral oil, this was just a thought, then I was just trying to figure out what went on in this compartment with the blanking plug on the end of it. Thanks for the input.
452009
Reply By: bunner68 - Tuesday, Sep 12, 2006 at 11:12
Martyn,
I had the same problem on my Nissan and what a drama. 2 separate mechanics advised that it was the pulley seal. After having the seal replaced and the belt (because they said there was oil it) there was still a leak. Took it to Nissan who said that one of the 'blanks' had a crack in it and that it was from wear and tear. Found out after quite an argument that it was a fault during the casting of the sump. Apparently not a warranty issue. After much tooing and froing Nissan pulled off the sump and advised that the sump seal was faulty. Again, not a warranty issue. They advised that they would have to reseal the sump etc.. which they did. At my expense. I went to the head office in
Melbourne and complained to no end. I got zip. At the end of the day you will have to get someone to pull off the sump, have a look at the blanks for cracks and then have the sump seal assessed and quite possible replaced. The seals are not like the old gasket ones it is some form of hard setting glue. After
mine was replaced I have not had a leak but I was out of pocket.
hope this helps.
194116
Follow Up By: Martyn (WA) - Tuesday, Sep 12, 2006 at 11:17
bunner68,
Great thanks, just what I wanted, did you ever find out what the compartment was for? It must have some purpose. Did they have to take the engine out to get the sump off?
452012
Reply By: Member - Hugh (WA) - Tuesday, Sep 12, 2006 at 11:20
Hi Martyn,
I'll have a look at CD manual tonight to see if there is any more detail on this. I haven't had a close look at
mine so unsure of function of that part of the sump, however the hole looks to me like a cross drilling. These are often sealed with a ball bearing pressed into the hole (cheaper than machining and plugging and very effective in Al). If it really is leaking from there then perhaps integrity of the seal in question but I'd be suprised if this is so. How far up hole can you reach?Assume only a couple mm.
Anyhow, I'll get back to you tonight.
Regards,
Hugh
194118
Follow Up By: Martyn (WA) - Tuesday, Sep 12, 2006 at 20:46
Hugh,
This would be great if you can email anything to me please do, Ta
452100
Reply By: bunner68 - Tuesday, Sep 12, 2006 at 11:23
No mate I never found out what the 'blank' was for, in the end I just got sick and tired of being run around. I think Nissan rely on that fact.
They didn't have to take the motor out. I believe they had to drop the front diff and gearbox to gain access. While they were in there I had them do a service and the bill was around the $900.00 mark. When I went to pick the car up one of the guys told me that this was in fact wrong and I should not have been quoted that figure. The cost was more like $1200.00. Old mate wasn't going to give me my keys. After a mexican standoff I got my keys.
Looking at your picture that leak is higher up and is in the exact same place as
mine was.
Good luck.
194119
Reply By: donks1 - Tuesday, Sep 12, 2006 at 11:26
zd30's have two "sump plugs"
one at the front , one at the back....
the front one shouldn't be touched.. they are a tapered thread and when you screw it back in, it will generally crack the sump.... plenty of people have made this mistake...
not sure if this relates to your car but as earlier posts suggest, leak may be coming from nearby and pooling at this point
194120
Reply By: 3.0turbob - Tuesday, Sep 12, 2006 at 12:33
Martyn
Mine has the same oil leak, but I can see that it's comming from the plug at the front (on
mine). I can't find any referance to this plug in the manual either and I assume its some sort of casting from manufacture and they've just put a screwed plug in to block it. I've been meaning to remove it and seal it with thread tape, but ......you know..... next oil change ... or maybe the one after that. It's been that way for 3 years now, doesn't drip oil on the driveway, so I haven't been too concerned about it.
Rob
194126
Follow Up By: Lyds- Tuesday, Sep 12, 2006 at 23:05
my td30 had a leak around that threaded plug. The mechanic wouldn't touch it and suggested Nissan would fix it under warranty - which they did.
452131
Reply By: Member - Jeff M (WA) - Tuesday, Sep 12, 2006 at 12:34
Sikaflex = solved :-)
I had a 2.5" crack in my compressor sump on the little GMC (compressor fell on it's side). Didn't even clean the oil off, whacked some sikaflex on it and it's never leaked since! HAHA. If all else fails, just do that.
194127
Follow Up By: Mazdan - Tuesday, Sep 12, 2006 at 15:38
Thats exactly what I would do.
452050
Reply By: Martyn (WA) - Tuesday, Sep 12, 2006 at 20:45
Forumites,
Thanks for the reponses, I'm taking the sump off. The engine was due an oil change and there doesn't seem to be much in taking the sump off. For the sake of a couple of hours work and a gasket this seems to be the easiest option.
Yes it is a bit of a cross drilling as mentioned but for the life of me I can't see what the function of the cavity behind the plug is. This plug can't be the second sump plug, nothing came out when the engine was full of oil.
I like the Sikaflex idea but it's just not the way I want to do it, off road somewhere isolated no home comforts, pass me the tube I'm in. Garage easy access bit of time, do the job right first time etc etc.
Hilly if you read this say nothing OK.............
Hugh, if you find out that would be great I'm interested. I'm sure this never used to be a hole because the oil used to try to leak out of the plug I fixed this with Ultra Blue, I like the idea that the ball bearing fell out, if this is the case I'll be welding it up, end of problem for ever. Yes I will check the gasket face for straightness.
Again thanks to all for the responses, good effort. any further ideas "bring it on"...................
194213
Follow Up By: jon p qld - Tuesday, Sep 12, 2006 at 22:11
Martyn, taking the sump off is a very big job, you will need to remove the gearbox, as there are two hidden bolts which cannot be accessed without the gearbox removed. gearbox removal is also a difficult operation on a ZD30 Patrol as it needs to be rotated about 45 degrees for the starter motor mounting flange to clear the floor pan and the gearbox is very heavy. This is assuming yours is a manual and not an auto as I've never had to remove an auto box. Certainly not a job I would be attempting at home.
Regards Jon
452119
Follow Up By: Martyn (WA) - Tuesday, Sep 12, 2006 at 22:36
Thanks, that bit didn't get a mention n the books I read, might have to go to plan B in that case.
452126
Follow Up By: Martyn (WA) - Wednesday, Sep 13, 2006 at 09:23
Jon p,
Thanks for the advice how right you were, saved me getting into more poo than I needed to get into. Plan B is a definite now.
452182
Reply By: nonon - Tuesday, Sep 12, 2006 at 21:08
Martyn, this hole is not where the oil is coming from.
Mine has oil around the same area as yours.
I had the area cleaned at the major service [80,000] and it has taken until the next major service [120,000] to get as bad as yours which means whatever is leaking is very slow and personally it can stay that way.
I got better things to do than naff around with sump gaskets and phsuedo sump plugs because of something so innocous.
194218
Reply By: Bob on Patrol - Tuesday, Sep 12, 2006 at 21:56
Martyn,
Same 4wd same oil leak. Nissan had several attempts at resealing the plug but the leak continued. Finally they suspected that the sump may have a crack in it and the dealer got approval to replace the sump under warranty ( no this was not the
well published larger sump as it does not exist, that fix was simply making the dip stick shorter to increase the oil required reach the required marks).
Involved obviously removing the sump but they "discovered" the leak was coming from further up the front of the engine due to inadequate gasket sealant. Had to remove the pulleys and a section at the front of the engine immediately above the sump to "fix" the problem. They also replaced the timing case oil seal (I think) anyhow the whole job took them 3 days and they still put the new sump on even though there was nothing wrong with the old one.
Everything was fine for a few months but eventually the leak returned and continues today. It is only very small and I keep a regular check on it. The main problem as I see it is the nissan dealers do not know enough about the patrol and the 3.0lit engine and attempt cosmetic fixes in the hope it may work or untill the warranty runs out. In my case they got a bit more serious but in reality they had no idea and I still have the leak but a new sump, and it is no longer their problem. It appears to be a common problem but not a serious one. In all the foums I have read I have seen this leak mentioned often but I still have not seen a pemanent fix.
Good luck with yours.
194227
Reply By: Member - Hugh (WA) - Wednesday, Sep 13, 2006 at 00:06
Hi Martyn,
Please find below image of the sump from within. The o-ring make me think this is an extension of the pressurised oil circuit. Given that this engine is used in other applications other than Patrol (Renault buses, etc), I'd suggest that this might be for other purposes (oil cooler perhaps). Not that you'd do that on a GU Patrol due aircon drive belt in the way. I assume that your Patrol must be a manual. The reason being that I couldn't find the weep hole - turned out I have a bolt going in there to attach the auto trans cooler support bracket (refer image below). Could be that on the auto they seal via bolt. If you really think it is coming from there, then I'd degrease and fill with Sikaflex as mentioned.
I have a very slight weep from the BSP plug. Not enough to be worried about. Another option here is to degrease and then apply some wicking to the exposed threads - that should assist sealing without removing the plug.
If you want to borrow my CD let me know but this is about all I could find. No image of the bottom of the crankcase structural plate for mating feature.
Regards, Hugh
!MPG:5!
194251
Follow Up By: Martyn (WA) - Wednesday, Sep 13, 2006 at 09:20
Hugh,
You've been a great help thanks for the effort, The leak is a bit more than a weep. As earlier post pointed out the sump is easy to remove right up to the point where you have to get the two secrect bolts out which are hidden in the gearbox bell housing, thank goodness for the Exploroz web site I say. The bolt you mention may have fallen out of my sump, there are a couple of guys at work who have GU's I'll be taking a look in the
carpark today to confirm.
About the CD anytime, if you email me or I email you we could start from there. Again thanks
452180
Reply By: CHRIS UREN - Wednesday, Sep 13, 2006 at 09:38
Martin,
My brother in-law has the exact same problem with his ZD-30, and i have the good fortune to work with a bloke who used to be the workshop foreman at a Nissan dealer here in
Melbourne.
When i quizzed him about the said leak, he informed me that he has experienced this problem with ZD30's a few times, and the problem stems from an o ring buried deep inside the timing case cover, so to fix it they have to dismantle the front of the engine, which is very labourious, and then has to be put back together with new o rings and sealant, and this has to be done exactley right otherwise the leak will return.
My brother in-laws is getting rectified under warranty, so i imagine yours should be also.
Hope this has been helpfull.
194283
