Sticking Throttle - TD4.2
Submitted: Friday, Sep 15, 2006 at 08:02
ThreadID: 37727 Views:4408 Replies:11 FollowUps:3
Hi Guys,
Has anybody seen this sort of thing before?
Occasionally, throttle seems to be sticking and not returning to idle.
The very first time it happenned in the other direction ie. wouldn't accelerate past about 2000 rpm.
Since then it's been sticking occasionally - notice it on gear change (always changing up) - revs to around 3500 - 4000 rpm.
Stamping on the accelerator a few times has managed to free it on most occasions - did resort to turning the ignition off on one occasion.
Respected mechanics can't find anything, have lubricated cable etc.
2002 Patrol TD4.2 with Autron cruise control. Cruise control has been off for every occurrence.
Timing could be worse, I suppose - off to Red Centre for Vic School hols!
Appreciate the benefit of anybody's relevant experience
Thanks & Regards
PGK
Reply By: Mazdan - Friday, Sep 15, 2006 at 08:05
If its a carby vehicle then it could be wearing throttle linkages or shaft.........I have had that problem.
Its also possible that the cable has a small fray in it somewhere.
Another I have seen is where the ends jump out of there holders ie in the cab at the acelerator.
AnswerID: 194634
Reply By: Member - Roachie (SA) - Friday, Sep 15, 2006 at 08:16
I'd be disconnecting the throttle cable where it attaches under the bonnet. Check that the cable is "free" to move in both directions. Check that the throttle mechanism itself will turn in both directions quite freely as well. It could be a buggared return spring. I'd also look at getting the Autron set-up temporarily disconnected, as that may be causing the problem in the 1st place due to a sticking cable etc.
Good luck........ most of the time problems are caused by after-market stuff.
Roachie
AnswerID: 194639
Reply By: Member - JohnR (Vic)&Moses - Friday, Sep 15, 2006 at 08:42
I once saw where a mechaninc "adjusted" the throttle cable to get the idle speed right and actually had bent the end of the shroud, causing the throttle to stick.
AnswerID: 194643
Reply By: Member - Wayne N (QLD) - Friday, Sep 15, 2006 at 09:37
Hi PGK,
Had a similar problem with my 4x4.
Check the end of the of the cable that goes to your cruise control by manually opening the butterfly. Mine was becoming worn and frayed, causing to not slide freely inside the outer cable.
regards
Wayne
Crossing the Wenlock
AnswerID: 194652
Reply By: Member - 'Lucy' - Friday, Sep 15, 2006 at 11:56
Wouldn't happen to a JEEP
AnswerID: 194673
Follow Up By: Member - Roachie (SA) - Friday, Sep 15, 2006 at 15:55
Nothing ever happens to a Jeep!!! How can it when they are always tucked away safely at the repair shop?
FollowupID: 452752
Follow Up By: Member - 'Lucy' - Friday, Sep 15, 2006 at 17:55
Shut up! you nissan driving menace
FollowupID: 452772
Follow Up By: junior - Saturday, Sep 16, 2006 at 01:33
Come on Lucy- at least call us DATSUN driving menaces!!!
FollowupID: 452831
Reply By: PGK - Friday, Sep 15, 2006 at 15:40
Thankyou people - appreciate the pointers
(and Lucy!)
PGK
AnswerID: 194696
Reply By: Michael ( Moss Vale NSW) - Friday, Sep 15, 2006 at 20:40
Check that the linkage is not snaging on the hand throttle cable. This is a separate cable, check the operation of this. Michael
AnswerID: 194740
Reply By: Member - Andrew W (SA) - Friday, Sep 15, 2006 at 22:06
check the driver's side mats
AnswerID: 194762
Reply By: junior - Saturday, Sep 16, 2006 at 01:34
....... and the flux capacitor
AnswerID: 194780
Reply By: JamieMac - Monday, Sep 18, 2006 at 22:26
Check the Fast Idle actuator for the air con as that was the problem in mine
JamieMac
AnswerID: 195197
Reply By: PGK - Tuesday, Oct 03, 2006 at 08:55
Thanks all
Disconnected the Cruise control - sticking still occurred
Checked hand throttle cable - free, even when throttle was stuck
Back from the trip & have had no sticking throttle problem since the Mereenie Loop Rd - seems as though something has rattled back into place.
I'm none the wiser and likely to revert to blissful ignorance!
Um, what's a flux capacitor?
PGK
AnswerID: 197583
