Oil problem on 80 Series??
Submitted: Friday, Sep 15, 2006 at 09:24
ThreadID: 37732 Views:13807 Replies:7 FollowUps:10
Hi all,
I have a '94 GXL Petrol 80 Series 1FZ-FE with two oil related problems. The oil in it is Penrite HPR15 (Semi Synthetic 15W-50 or 60 I think) and is approx 5000km's old.
First problem has been present regardless of what oil I use and that is that it's fairly difficult to get an accurate oil level reading off the dipstick. The oil is usually 'smeared' a fair way up the dipstick and there is no definite 'level'. This is the case whether the truck is hot, or has been sitting level all night and is stone cold. Any ideas??
Second problem is, the oil light has started to come on lately. As far as I can determine (considering problem #1) the oil is 3/4 the way up from the add line and the full line so the light shouldn't be coming on yet for low oil level should it? Also is this standard oil usage for this sort of truck with 220k on it? The other thing is that the oil pressure gauge (standard in dash type) shows good pressure so this prob isn't the cause for the oil light either! Any ideas???
Thanks for reading and I hope someone can shed some light on my probs!
Scoey!
Reply By: Member - Phantom (WA) - Friday, Sep 15, 2006 at 10:01
Hey Scoey,
My Cruiser sounds like a twin of yours. Same year, same kms. I also have problem reading the dipstick which I check regularly *every day when travelling). I also get really good oil pressure on the gauge which has never moved since I've owned it. Mine has never used a drop of oil between services. Don't know the answer to your problem however.
Steve
AnswerID: 194653
Follow Up By: Scoey (QLD) - Friday, Sep 15, 2006 at 10:54
G'Day Steve,
It does sound like we have a set of twins! ;-) Your's isnt' that bronzey gold colour by any chance eh? ;-) Mine has always (read: in the 2 years I've owned it) used a little bit of oil but never much. I have heard that this is a common problem but I've never had any good info to back it up. Hope someone can shed some light for us then!
CHeers
Scoey!
FollowupID: 452706
Follow Up By: Exploder - Friday, Sep 15, 2006 at 11:37
Get the oil pressure checked with a mechanical gauge off the engine block any workshop should be able to do this for you. You can then determine wether the light is faulty or your oil gauge or both.
FollowupID: 452711
Follow Up By: Scoey (QLD) - Friday, Sep 15, 2006 at 12:01
G'Day Exploder,
Thanks for the tip - I'll look into it. I've contemplated installing a decent Oil Pressure gauge for a while now - maybe I should just pull my finger out! hehe!
Scoey!
FollowupID: 452716
Follow Up By: Member - DOZER- Sunday, Sep 17, 2006 at 21:20
Add a nother litre of oil, the light is an oil level light, not a pressure light...the gauge gives you pressure readings.
Andrew
FollowupID: 453054
Reply By: Toy_Hilux - Friday, Sep 15, 2006 at 11:35
Must be triplets. Mine had the same problems. Though only 180k. I went back to using straight 40grade oil and solved problem with reading. It also uses about the same oil between changes. It must be that 5000kms mark as that is when my light also starts to come on. We have even tried changing the oil sender but too no avail. Was told that light starts to come on when oil level drops from full line and not at the add oil line (must be an engine saver). All we do now is change the oil every 5000km and no problems. Must just be all our driving off the black top. At least at every 5k, I know that there is good clean oil in it all the time and I know if something is going wrong in the internals. Hope you sort your prob out and continue to enjoy this great country.
AnswerID: 194667
Follow Up By: Scoey (QLD) - Friday, Sep 15, 2006 at 12:04
G'Day Toy_Hilux,
It's starting to sound like a common problem. So exactly what oil do you use - I'd be keen to know! I tend to do 10,000k oil changes and they seem to go ok for me. But then again, the ol girl probably doesn't do AS much hard work as yours!
Scoey!
FollowupID: 452718
Follow Up By: Toy_Hilux - Friday, Sep 15, 2006 at 12:31
Scoey,
I use Mobil XHP Plus 40grade. Our mechanic even recs 5k service as our climate is alot harsher than where our vehicles are designed. It is supposed to have something to do with our temp and environment or so they recon. In the end I just thought that by having shorter oil changes (might cost a bit more) it would save alot than having to replace the old donk. Anyway, it worked for me. Hope you find a solution to yours.
FollowupID: 452725
Reply By: Member - Howard (ACT) - Friday, Sep 15, 2006 at 12:42
On my 92 1 fz-fe (from about 300,00 plus)I was running valvoline xld and oil pressure started to drop even though I used no oil between changes done @ 10K.
I changed to XLD premium and oil pressure reading went back to normal .
I now find however that the oil light sometimes comes on after between 8-9,000km or even earlier if i do a long day say 1000-1200km.and I need to add a pint to get thru to the next service.
I guess the evaporation of contaminants in the oil lowers the level when truck runs hard.Light doesnt come on if only short trippping.
vehicle now has 400,000km plus and never been opened up so cannot complain.
Howard
Resigned to Retirement
AnswerID: 194675
Follow Up By: Scoey (QLD) - Friday, Sep 15, 2006 at 14:12
Thanks for the feedback Howard! I appreciate it!
Scoey!
FollowupID: 452741
Reply By: Moose - Friday, Sep 15, 2006 at 13:19
G'day Scoey
I have a 96 with a few more k's than yours.
Just wipe dip stick and re-read. May take a couple of goes but you'll get a clean read.
My light comes on when the reading is near the bottom mark. Just keep it topped up and no light.
Mine uses a bit of oil but not enough to worry about.
I change at about 10,000 ks.
I use bleep s oil (from Sunshine State 4WD at Archerfield). Have used that for yonks.
Cheers from the Moose
AnswerID: 194680
Follow Up By: Moose - Friday, Sep 15, 2006 at 14:09
Apparently the oil I use has activated the naughty word catcher. It's F U C H S. (Or maybe I typed it in wrong:-)
FollowupID: 452739
Follow Up By: Scoey (QLD) - Friday, Sep 15, 2006 at 14:27
G'Day Moose,
Thaks for the info - you guys are starting to allay some of my worries! :-) hehe bleep s oil eh? I'm quite fond of bleep s so I might get some for my truck! ;-))
Scoey!
FollowupID: 452742
Reply By: Member - andrew B (Kununurra) - Friday, Sep 15, 2006 at 13:27
Gday Scoey
just a quick thought on the dipstik, there may be a bit of soot/sludge buildup in the dibstick filler tube. A bit of a clean prior to dropping the oil next change may help.
Cheers andrew
AnswerID: 194682
Follow Up By: Scoey (QLD) - Friday, Sep 15, 2006 at 14:28
G'Day Andrew,
Thanks, I'll check it out next change!
Scoey!
FollowupID: 452743
Reply By: 120scruiser (NSW) - Friday, Sep 15, 2006 at 20:08
Gday Scoey
The toyota genius's designed their engines with a low oil level sensor in the sump. Most have these. When the oil gets to a certain level the float puts the light on. When they play up the light tends to flash on as well.
However I have just converted a 1HZ 100 series to a 1HDT and it has no low oil level sensor. Try unplugging it for awhile and see if this rectifies the light as I think they are expensive.
My second comment is 15/50 or 60 oil is way to thick. The later 1FZ FE engines are recommended to run a 10w/30 oil for optimum fuel economy and quick lubrication on start up however a 15w/40 SL grade oil is just as good. In my workshop most get 15w/40 and once this engine is in a 100 series I put 10w/30 SL oil in them. I am a promoter of the modern day thin engine oils.
Hope this helps
120scruiser
AnswerID: 194734
Reply By: craig - Friday, Sep 15, 2006 at 20:18
Hi Scoey
Same engine 1FZ-FE and same oil HPR15 on a 97 with 155 000 km. No problems at all with oil pressure. What I have found with the dipstick is that it smears on one side, if you turn it around you should be able to read the level.
Craig
AnswerID: 194737
