Gas Fridge Repairer
Submitted: Wednesday, Sep 20, 2006 at 08:39
Vic
Hi All,
It's a bit off topic, but I reckon you lot are the best
forum for just about anything! Anyway, here goes! I have an OLD (1950s) Electrolux kero fridge that has been converted to LPG. I use it on my bush block to keep the milk and the beer cold, but after cleaning the flue last week, the bloody thing doesn't cool any more. The flame is fine, and the baffle is back in the flue, but it just seems to be airlocked or blocked up. I disconnected it and tipped it side to side (it weighs about 450 lbs), but NOTHING. Does anybody have any ideas, or know of a decent repairer on the east or north side of
Melbourne?
Thanks for your thoughts.
Vic
Reply By: TerraFirma - Wednesday, Sep 20, 2006 at 11:03
1950's...! 56 bleep in years old, thats older than most of us here..! If you have a bush block put her out to pasture and leave her in peace..!
195483
Follow Up By: Vic - Wednesday, Sep 20, 2006 at 14:00
Easy to say - hard to lift! And, sad to replace a fine old piece of machinery with a modern piece of plastic rubbish!
It would make a good bomb shelter though.......Hmmm
453605
Reply By: Member No 1- Wednesday, Sep 20, 2006 at 11:28
is that all you did...clean the flue? and how?
195489
Follow Up By: Vic - Wednesday, Sep 20, 2006 at 13:57
I cleaned the burner, just brushed it off, and took the baffle out of the flue, which scraped the slight amount of soot off the sides.
The jet is clear, and the flame is as good, or better than before. I didn't really bang or knoock anything, but now, after an hour or so, the tube out of the top of the 'boiler' gets quite hot, but the hot stuff doesn't seem to move around at all.
It worked perfectly
well until I 'fixed' it!! It would freeze a couple of trays of ice within 2 hours.
I'm sure there's a message........
453602
Follow Up By: Member No 1- Wednesday, Sep 20, 2006 at 17:38
Questions:
1. did you turn it upside down or on its side, while or before you cleaned it
2. how long have you let it run for? (since you cleaned it)
453649
Follow Up By: Vic - Wednesday, Sep 20, 2006 at 23:07
Answers: 1. No, it's all I can do to move it away from the wall!
2. A couple of days, and not a hint of cold. In the past, the freezer would start to ice up within an hour of light off.
453719
Follow Up By: Member No 1- Thursday, Sep 21, 2006 at 07:49
Re-read your earlier reply wherein the flame seems "better than before"...it isnt too high?, Have you tried turning the flame down to about half and then try it?
They do need heat in the generator to work but too much also causes problems!
another question:
you didnt scrap the evaporator of ice?
If that doesnt work you can only try turning turning the fridge on its side to clear a possible restriction ...could be foreign matter or even crystalisation. You mayy need to leave on its side for a couple of hours, then its back and then upside down, then the other side.....does not have to be in that order just so long that they are all done. Try it as soon as its stood up.
453754
Follow Up By: Member No 1- Thursday, Sep 21, 2006 at 07:53
oh ..and if that doesnt work try that procedure again a couple of more times!
you did clean the the rear of the fridge also didnt you?
Double Check to make sure the flame is under the stack and not to one side.
Do you own a boat by any chance or know some one who does:)
453755
Follow Up By: Vic - Thursday, Sep 21, 2006 at 11:20
All sounds like good advice,
I'll try the turning it over/around/upside down thing, and also- maybe before I move it, run it at half flame.
I cleaned the back, and also checked that the flame is right under the flue.
I'd need a big boat, or as it slid silently into the
water, and the chain unwound, we would surely follow it to the deep dark depths! Man, it's heavy!
453783
Reply By: Mike Harding - Wednesday, Sep 20, 2006 at 12:29
Is it designed to withstand a first strike from an ICBM?!!!!!
At 450lbs I don't fancy your chances but... I have heard it said that the ammonia based cooling system in absorption fridges can develop a vapour lock, or something, and standing the fridge upside down for a couple of days then righting it and letting it stand for another day before lighting it can solve some problems.
Another post mentions K-mart will be selling Jackaroo 3 way fridges tomorrow at $300, you may be interested in one of those?
Mike Harding
195497
Follow Up By: joc45 - Wednesday, Sep 20, 2006 at 16:22
I've heard the same remedy - turn it upside down for a while. Nothing to lose....
453632
Reply By: Member - len W (NSW) - Wednesday, Sep 20, 2006 at 16:03
hi there you havnt knocked the thermostat away from the flame by any chance
.len
195525
Follow Up By: joc45 - Wednesday, Sep 20, 2006 at 16:21
Not sure that thermostats were invented when these fridges were around!!
453631
Reply By: Member - len W (NSW) - Wednesday, Sep 20, 2006 at 16:34
im not sure about your fridge but the ones i have seen converted to gas had a thermostat just over the flame . also from memory i think that fridge needs a twisted piece of metal in the flu it should be on a wire maybe its some kind of restrictor { if there is a word like that lol} or something
len
195528
Follow Up By: Vic - Wednesday, Sep 20, 2006 at 16:42
Yeah, there's a restrictor in the flue, which is a twisted piece of copper. It spreads the heat around in the lower part of the flue where it heats the liquid (I guess).
The thing in the flame is the safety cutoff thermocouple - and it's working fine. There is a thermostat thermocouple as
well, and it feeds into the back of the cabinet up the top, and controls the flame to either High or Low. That all seems to work OK - just no COLD! Cheers, Vic
453636
Reply By: Member - len W (NSW) - Wednesday, Sep 20, 2006 at 17:02
well im not much help to you i guess the only other thing i could suggest and its a heavy one is to turn the bugger upside down to get the gas in the fridge moveing that is a trick to do for caravan fridges that stop getting cold good luck ....... len
195536
Follow Up By: Vic - Wednesday, Sep 20, 2006 at 23:13
Thanks Len,
I reckon I'll give that a go when I get up there again. It'll take two of us to lay the blighter down, then tip 'er up on end, but it's still easier than floating it to a repair
shop! Cheers.
453721
Reply By: Member - Julie P (VIC) - Thursday, Sep 21, 2006 at 07:29
Hi - there is a place called simply - Caravan Refrigerator Service - or very similar they are in or around the Moorabbin area - good people to do business with.
They will be in the phone book. Know their stuff.
195628
