Saturday, Sep 23, 2006 at 09:44
I have a Heron 2.2 and the Honda EU20i.
It runs my air-conditioner perfectly
well, when running on full throttle. ..It can handle the startup required by the air-con (spike power @ 2200 watts), however, if I switch the Honda to "eco-throttle", it is unable to keep up with the air-conditioner compressor start up and goes into overload mode (ie it can not handle the peak power demand for the air-conditioner startup when its generator is at "idle", it tries to speed up, but not quick enough).
I suspect a Honda EU30 may have more low down power grunt to handle the "eco-throttle", but have not tried this. - The Honda EU30 is a much bigger and heavier unit.
If you are happy to run the EU20i at full throttle while air-conditioner is on, then you have a solution, but not one that could make it through the night (approx 4 hours from the Honda EU20 at full throttle).
I have not been able to work a solution to get my air-conditioner to run through the night on my EU20i, apart from waking up and refilling the
fuel on the Honda.
Taking advantage for theomostat control on the Heron and eco-throttle on the Honda is my ultimate goal - I suspect some additional "inverter" spike battery booster may help the equation, but I cannot work this out:-(
454280
