Q: Engine swaps - Crusier 3F into a 2F engine bay??
Submitted: Friday, Sep 29, 2006 at 20:25
ThreadID: 38155 Views:5684 Replies:5 FollowUps:5
I have 2 Toyota crusiers - a 1985 3F petrol very terminal rust issues+++ and a good sounding engine.
The other is an 1983 2F petrol with good body with a major engine knock but running.
QUESTION: Are these engines easily swapable 2F into 3F engine bay??
Engine mount placement etc????
Advice sought
Paul
Reply By: GaryInOz (Vic) - Friday, Sep 29, 2006 at 21:39
Going by the way Toyota label their engines I would say there shouldn't be a major problem. The descriptions of the engines are the first letter describes the basic block and the number that precedes it is almost the "revision" or version of that engine, the higher the number the later the engine. so your 2F is and earlier version of the 3F.
I'm no expert though....
AnswerID: 197224
Follow Up By: Paul217 - Saturday, Sep 30, 2006 at 09:09
Thanks Gary, I will give it a go
FollowupID: 455725
Reply By: Topcat (WA) - Saturday, Sep 30, 2006 at 00:10
Hi Paul. You shouldn't have any problems. Did a similar engine swap in the same models you mention a few years back. The engine went in like a dream. Cheers
AnswerID: 197237
Follow Up By: Paul217 - Saturday, Sep 30, 2006 at 09:10
Thanks Topcat
FollowupID: 455726
Reply By: Muzzgit [WA] - Saturday, Sep 30, 2006 at 01:17
As far as I know, same block, different crank-rods-pistons, different head.
AnswerID: 197242
Follow Up By: Paul217 - Saturday, Sep 30, 2006 at 09:11
Thanks Mate
FollowupID: 455727
Reply By: ross - Saturday, Sep 30, 2006 at 20:40
American 60 series landcruiser had the 2F until 87 .
There is a slight height differnce between the two with the 3F being 6mm lower which is the differnce in stroke btween a 4.2 litre and a 4 litre.
It will fit no problems but putting the older motor in a newer car may be techinically illegal.
AnswerID: 197306
Follow Up By: Paul217 - Tuesday, Oct 03, 2006 at 00:00
Will check out the legality issues, thanks
FollowupID: 456060
Reply By: Member - DOZER- Monday, Oct 02, 2006 at 23:02
Bolt straight in...engine pipes will be different...
Andrew
AnswerID: 197544
Follow Up By: Paul217 - Monday, Oct 02, 2006 at 23:59
Thanks Andrew
FollowupID: 456059
