05 Mitsubishi Challenger gearing noises????????????
Submitted: Sunday, Oct 01, 2006 at 08:42
Craigo69
Hi there, I am hoping someone can help me!!! 10 weeks ago I bought a new, runout model 05 Mitsubishi Challenger (auto) and had to have the transfer case completely replaced ( a very long and trying story with Mitsubishi) after discovering a problem with it when I used it in 4 High for the first time (3 days after driving off the showroom floor).
Anyway, now (after waiting nearly 2 months) the transfer case has been replaced, I am getting gearing noise when I place it in 4 High and in the Low gears. They are not loud gearing noises but are certainly audible. Is this normal? The gearing noise is not evident in 2 High for normal everyday driving.
I am hoping that someone else out there with an auto challenger or knowledge of such, can please help me before I speak to Mitsubishi again!!!!
Many thanks,
Craig
Reply By: Trevor R (QLD) - Sunday, Oct 01, 2006 at 09:10
Hi Craig,
Could it be you are trying to hear something as you have not exactly had the best start with that vehicle. I have just had the gearbox/transfer rebuilt on the Patrol and also have gear noise but I am putting that down to brand new gears and they may take time to bed in, if I still have noise in 1000km then it will most certainly be going back in my instance.
The beauty in your instance is the Mitsubishi warranty, you have plenty of time to get it sorted if it is not a brand new gear problem that needs to bed in. I would still
jump up and down at Mits on Monday so your dealer is at least aware of your concerns and should be more inclined to help if it doesn't settle down in a thousand k's or so.
Hope it settles for you and you can enjoy the car for what you bought it for.
Regards, Trevor.
PS I had an auto Pajero in 96 that I wanted to sell after 2000km cause I hated the noises coming from the auto box on that thing and it lasted
well till I sold it 170000km later. Maybe it is how it is supposed to be???
197341
Follow Up By: Craigo69 - Sunday, Oct 01, 2006 at 09:15
Thanks for the advice Trevor, I hope that is the case!
455810
Reply By: kev.h - Sunday, Oct 01, 2006 at 10:39
Hi Craig
In 2H you are not driving the transfer case in 4H you are so the noise in the FWD bits not sure if the new ones are gear or chain drive the chain drive ones get a chain noise in 4WD ( sounds like a bike chain) if that is all it is no problem may pay to ask what the drive system is ?? also when new in 4WD you have front diff gear/drive shaft noise thats not there in 2WD which changes the sound of the car
Regards Kev
197346
Follow Up By: Craigo69 - Sunday, Oct 01, 2006 at 16:57
Thanks Kev, now that you mention it, it does sound a bit like a vibration/chain noise. I will endeavour to find out whether or not it is gear or chain driven.
455877
Reply By: Member - 'Lucy' - Sunday, Oct 01, 2006 at 15:30
Is it possible to give a more definedr description of the 'noise/s' rather than a general 'gearing noise'.
As Trevor said, once you leave 2H there are 'noise'/s' which are normal.
197363
Follow Up By: Craigo69 - Sunday, Oct 01, 2006 at 16:58
Thanks Lucy, see Kevs follow-up!
455878
Reply By: Member - Oldplodder (QLD) - Monday, Oct 02, 2006 at 07:59
You could try the mitsubishi club
forum.
May need to be a little more specific, or if you are not sure, ask about tying the noise down.
forum.pajeroclub.com.au/forum/
Other challenger users on this
forum.
Mine is only super select I, not super select II, but I get some gear noise.
With all of the other noise (louder exhaust, and other rattles in the 10 year
old car), not so audible any more in
mine.
But you need to check it out.
It isn't like a mild gear crunching sound? Get this when the 4wd is not properly engaged. Do the dash lights keep flickering? If they do, 4wd has not engaged properly. You may ned to be firmer with the selector lever to actually engage the gear.
Is this your first mitsubishi 4wd? Maybe get a friend with a pajero or challenger to try it for you?
197420
Follow Up By: Craigo69 - Monday, Oct 02, 2006 at 13:52
Yes this is my first, and hopefully not last 4WD. The indicator light does stay on when 4H engaged. The sound is more like a vibration or grinding type sound, hard to say, I dont know whether or not the transfer case is run on chain or gears in my 05 model. When I had the first problem with the transfer case (which eventually got replaced0 it was a definite grinding/burring sound that would take a few seconds to disappear after 2H was reingaged. Now the sound is slightly different and appears when 4H engaged then disappears as soon as 2H is reingaged. Any thoughts! and thanks for your response.
Kindes regards
Craig
455954
Reply By: Zbub - Monday, Oct 09, 2006 at 22:52
Hi Craig - simple solution - pop down to your not so local dealer & take another Challenger for an umm "test drive" ;) Drop it in 4H on a nice straight stretch of road. If you hear the same noise you can relax.
Challengers do make a noise in 4WD - the only time you won't hear it is if other noises cover it up such as aggressive tyres or the radio
You won't hurt her putting it in 4H on the tarmac as long as you don't go around any sharp corners or leave 4H engaged for a long time. I've accidently left my Challenger in 4H & driven 20km to town & back & its only when pulling into a
parking space or if I turn the stereo down that I go Whoops !
198474
Follow Up By: Craigo69 - Tuesday, Oct 10, 2006 at 07:38
Thanks Zbub,
I have been keeping an eye out in our local yards to do the same. I have only managed to find a manual version so far.
You letting me know that there is some noises in 4H is also reassuring as I was beginning to be a bit paranoid about it all.
Craig
457185
