Corrosion in Anderson Plugs
Submitted: Wednesday, Oct 04, 2006 at 09:54
Member - Norm C (QLD)
I've just noticed that I have a bit of green copper corrosion in a couple of my Anderson Plugs. I've given them a good soak and spray with a bicarb and
water solution (about a tablespoon in a couple of litres on
water), then a thorough rinse in fresh
water.
I'll then spray with Lanaguard, Inox or similar. I do this from time to time, but obviously not often enough.
Will this solve the problem?
How important is it to get all the green off, or will the bicarb neutralize it enough if there is a little left.
Reply By: Member No 1- Wednesday, Oct 04, 2006 at 10:09
tarnish (vertigrease) increases resistance causing heat compounding the problem
197760
Follow Up By: Member - 'Lucy' - Wednesday, Oct 04, 2006 at 14:57
THANK YOU! all
Including you, you little blue eyed coota who obviously has nothing to do all day but sit on this
forum pushing my buttons.
Anderson Plugs, corrossion, resistance, heat, = fire and/or disaster.
I've had to get off my butt thanks to you lot and do some inspections.
Damn near had an accident getting outside to 'check things' just in case.
Result: nothing yet amd after I finish with the can of Wurths etc hopefully nothing in the future.
I thought Anderson plugs were 'bullet proof'
456342
Follow Up By: Member No 1- Wednesday, Oct 04, 2006 at 18:15
nothin is bullet proof....just ask the cat
blue eyed coota who has nothin to do all day?...hey, you dumb ass... my name aint willem..i work for a living....not like some others on here:)))))
456392
Follow Up By: Barry 2 - Thursday, Oct 05, 2006 at 02:05
If you work for a living !!!!! what are you doing answering this ?? you should be working for a living ??????
Hey, nothing wrong with being retired from the work force ?????
Your turn will come someday !!!
Just think that I have been retired long enough to enjoy this country when there is something to enjoy !!!!!!!!!!!!!!!!!!!!!!!!!
What can I say !! Curiosity didn't didn't kill the cat !!!!
I ran over it ????????????????
Have a nice Day
Bazza
456454
Follow Up By: Member No 1- Thursday, Oct 05, 2006 at 07:32
you ran over it?....you a nissan driver?
my turn will come... one day...the sooner the better...i can see my self liking the hours...but i reckon the pay is gunna be rat bleep e
456461
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Oct 04, 2006 at 13:46
I use Wurth contact cleaner and then inox.
Wurth
197785
Follow Up By: Member - Norm C (QLD) - Thursday, Oct 05, 2006 at 09:37
Thanks Derek. I'll see if I can get some and give it a go. I assume it is the OL, that I would use in my case?
456471
Follow Up By: Derek from Affordable Batteries & Radiators - Thursday, Oct 05, 2006 at 09:42
Hi Norm,
Yes OL
175A plugs are $12.50ea if you need to replace them but have you got enough cable slack to do so.
456472
Follow Up By: Member - Norm C (QLD) - Thursday, Oct 05, 2006 at 09:55
Plenty of slack on the trailer Derek, but might be a problem on the 4B. If it comes to that I'll check it out to see if I can pull some more through. The cable runs through the chassis, so I may have left a bit of slack in there. Be a bugger to have to replace the lot for the want or 2 or 3 inches.
456475
Reply By: Member - MrBitchi (QLD) - Thursday, Oct 05, 2006 at 08:19
In my experience once something like this (including battery terminals) starts to corrode the only sure way to fix it is to replace it. No matter how much gunk you spray, rub, paint on it the corrosion will allways come back :-((
197914
Follow Up By: Member - Norm C (QLD) - Thursday, Oct 05, 2006 at 09:35
I fear you may be right John, but I'll try the stuff Derek has suggested first.
One set of Anderson's I use is 175 Amp, so pretty expensive.
456470
